UPGRADED Rear SW Door - Defender Source
Old March 5th, 2012, 01:14 PM
]-[ @ n $'s Avatar
]-[ @ n $
Hans
Hunting
I'd like one of the new 1-piece rear doors for my '97 SW D-90. The original door is cracked in many places due to the weight of the tire.
The stealership told me they can't get the parts.
Anyone here upgrade their rear door? If so, how did you get the parts?
Old March 5th, 2012, 01:30 PM
KKilo23's Avatar
KKilo23
Kenny
Contact Justin @ Lucky 8. http://lucky8llc.com/
On here as Fivespddisco
or Stephen at Safari HP. http://safarihp.com/
SafariResto
Old March 7th, 2012, 09:53 AM
]-[ @ n $'s Avatar
]-[ @ n $
Hans
Hunting
Anyone hear if the upgrade is worth it?
I am trying to determine whether or not I should just weld the old door and add a Mantec tire carrier.
Old March 7th, 2012, 10:12 AM
bjf's Avatar
bjf
barry f
94 ST #395
New rear door is totally worth it.
Much nicer door card.
Galv door skin over a frame that is much stronger.
Rubber window seal.
Disco tire carrier.
I rewelded my door frame and went the Mantec route on my 110. The frame cracked again.
If you see the two doors next to each other you would see there is no comparison.
Old March 8th, 2012, 04:34 PM
mgreenspan's Avatar
mgreenspan
Matthew Greenspan
Land Rovers
Write Up on this topic. http://www.landroverexpedition.com/t...tyle-td5-door/
You little rebel, I like you.
Old April 12th, 2012, 12:52 PM
]-[ @ n $'s Avatar
]-[ @ n $
Hans
Hunting
Originally Posted by mgreenspan View Post
Fantastic resource! Thanks!
here is the parts list:
http://www.landroverexpedition.com/t...td5-rear-door/
Old April 12th, 2012, 01:01 PM
Is the newer rear door plug and play? I've put almost 50k of 84k on my SW, its had a tire on the door maybe 5k of those miles. I was surprised to see my door had a small crack in the frame.
Old April 12th, 2012, 04:06 PM
]-[ @ n $'s Avatar
]-[ @ n $
Hans
Hunting
From everything I've read, looks like a resounding "yes." Cheaper by the dozen? Sounds like we have 2.
Old April 12th, 2012, 04:17 PM
I have one of the new doors on a truck I'm building here and its a much more robust frame. Pain in the a$$ to mount the rear glass in the rubber gasket compared to the old design but much better design.
Old April 12th, 2012, 06:11 PM
Now to find one in conniston green that's not all beat up.
Old April 13th, 2012, 04:34 PM
]-[ @ n $'s Avatar
]-[ @ n $
Hans
Hunting
if I run across one, I'll let you know. I'm looking for one in Arles Blue should you find one.
Also, I have a quote for one from Lucky 8. More info as I have it.
door
SW Rear Door thud bjf Defender Technical Discussions 2 March 15th, 2009 03:19 PM
SW rear door questions WI-ROTTIE Defender Technical Discussions 11 October 23rd, 2007 02:38 AM
Rear door inner panel Kimos Defender Technical Discussions 4 October 15th, 2004 12:57 PM
Rear door table! TwisteD90 Defender Technical Discussions 10 April 5th, 2004 11:43 PM
Rear Door Hinge Replacement Rob Defender Technical Discussions 2 January 21st, 2004 01:26 PM
