Upgraded Hinge Prep and Install - Defender Source
Old May 18th, 2010, 08:59 PM
gas-man's Avatar
gas-man
Robert/Mazzarella
97/D90 ST: Sold
I bought the new hinges from Rovers North to replace my rusted ones and want to make sure I prep them properly. The hinges appear to be bear metal with a rough texture to them. Do I need to sand them before applying the first coat of primer? Do I sand between applying primer coats? I bought the AA yellow paint from paint scratch as well as some clear coat. Any suggestions would be appreciated since I plan to repaint my ST door cappings and a small rust area on the underside of my bonnet at the same time. Thanks.
Name:	paint, primer, clear coat.jpg
ID:	27752   Click image for larger version
Name:	door hinge.jpg
Name:	under bonnet.jpg
ID:	27754   Click image for larger version
Name:	door capping.jpg
Navy. It's not just a job, it's a job on a ship.
Old May 18th, 2010, 10:19 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
I am guessing you do not want to sand the hinges as you will remove the protective coating.
Clean well and maybe apply etching primer.
What are the specs on your aa yellow paint? Is that just a base coat in the can or a single stage?
I do not think I would use the duplicolor clear, products like that typically do not have hardner and do not hold up well.
Old May 18th, 2010, 10:39 PM
Mine are the same (but take offs from safari rover)
we roughed them up ans shot color, the were primed from the factory though
95' D90 - daily driver..
Euro 90 Swingout tailgate / POE liftgate install dave_lucas Smaller Projects 24 March 14th, 2016 04:01 PM
