upgraded axels? - Defender Source
Old September 30th, 2005, 12:18 PM
ripp2002's Avatar
ripp2002
L C
94 Defender 90
upgraded axels?
My saga grows and grows. My axel broke. Sent it to local parts store to order another one. They are telling me its an aftermarket axel. Question is any idea how to find out what type of axel? I can not get in touch with the person I bought it from.
Larry
Old September 30th, 2005, 12:19 PM
Roadsiderob's Avatar
Roadsiderob
Robert Dassler
1994 D90
Can you post a picture?...and which axle is it?
Rob
Rob Dassler
SWR Automotive
505-872-7818 (shop)
Old September 30th, 2005, 12:22 PM
sheki's Avatar
sheki
David Shechter
97' D90 SW 2.8L diesel
I would look at it this way, it's broken and needs to be replaced. Do you want to replace it with a OEM one or something beefier? I'm sure someone here on the board had a used OEM one they would sell cheap. If you are looking to upgrade go with Great Basin Rovers or Rover Tracks.
Which half shaft is it?
Old September 30th, 2005, 12:45 PM
ripp2002's Avatar
ripp2002
L C
94 Defender 90
Its the right front. I will get some picture of it and post them. As for upgrading or not I wouldnt mind either way. I take it the newer ones are a lot stronger then the oem? If I replace them what else needs to be replaced?
CV joint that broke. Ball and cage actually. Again I will take some pictures in a bit and let you know.
Larry
Old September 30th, 2005, 12:51 PM
sheki's Avatar
sheki
David Shechter
was it just the CV or was it the CV and the half shaft? Seems odd they would both break at the same time.
Old September 30th, 2005, 12:57 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
06 RR SC, 06 LR3, 94 D90
I highly doubt you have an after market CV/axle up front since you have stock wheels. To think about you could have ashcroft front axle kit. Do you have lockers/gears?
Upgraded Fan clutch part numbers for 4.0 btate Defender Technical Discussions 2 September 28th, 2009 05:21 PM
FS 2 Upgraded Weather Resistant Door Jam Switches Stmpede For Sale - Parts 6 March 13th, 2009 12:09 PM
Maxi Drive front axels F/S pushngo For Sale - Parts 2 October 8th, 2008 04:24 PM
front axels krisp For Sale - Parts 0 January 18th, 2007 02:55 PM
front axels & cv's krisp For Sale - Parts 2 February 9th, 2005 05:30 PM
