Upgrade Oil Cooler lines - Defender Source
Old October 2nd, 2015, 03:21 PM
Weldon's Avatar
Weldon
Weldon Pundt
"95" D-90
Any one on the form have a good source for Oil Cooler Lines?
Need to replace and would like to source and upgrade the lines/set up?
Weldon
Old October 2nd, 2015, 03:30 PM
http://www.defendersource.com/forum/...ade-47581.html
Old October 10th, 2015, 01:56 PM
Weldon's Avatar
Weldon
Weldon Pundt
"95" D-90
Reached out to railhead4x4.com, but no luck and/or returned calls/e-mails.
Any suggestions?
Weldon
Old October 10th, 2015, 02:37 PM
I pulled mine completely. Unless you live in a desert state they are probably not required.
Old October 10th, 2015, 03:27 PM
Grover's Avatar
Grover
Any suggestions?
I had my oil cool lines made by a local hydraulic shop. Maybe something to look into...
Old October 10th, 2015, 05:03 PM
chuckc4
chuck b
Registered User
you can always buy genuine ones from Rovers North. Aftermarket replacement lines and genuine lines will always need replacing in time--basic maintenance....
Old October 10th, 2015, 10:48 PM
Reached out to railhead4x4.com, but no luck and/or returned calls/e-mails. Any suggestions?
Try a few more time. Are you calling trailhead or railhead?
Old October 11th, 2015, 12:46 AM
Trailhead 4X4 & Off Road
7777 Exchange Street, Unit #6
Valley View OH, 44125
440.212.1636
Eric@trailhead4x4.com
95' D90 - daily driver..
Old October 11th, 2015, 08:54 AM
kevincdoyle's Avatar
kevincdoyle
Kevin C. Doyle
Hahahahahahahahah.....
Josh-you funny...
Attributed to Shayne...
Old October 11th, 2015, 09:09 AM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
What Chuck said.
Though, by "upgrading" you should aim to get something that does not spray toward the exhaust manifold when it starts leaking. I got a braided line setup for my D90.
Another option is to go with something that can easily be replaced. I have a setup on my Disco where I can go to any part store, get 4-5ft of tubing for cheap (< $10?) and get new lines. I'm banking on the fact that I will remember to change those every 50K miles.
Anyway, all those options have been discussed elsewhere.
Good luck finding what fits you best!
MonLand
1995 D90 NAS
1996 Discovery NAS
Old October 11th, 2015, 09:14 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
^ this ^
Rent my
Old October 14th, 2015, 02:35 AM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
^ this ^
Bullshit.
Old October 14th, 2015, 06:48 AM
Originally Posted by crown14 View Post
Bullshit.
Any context to this comment?
Old October 14th, 2015, 07:24 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
He just hates hot oil; likes it cool and sludgy.
Rent my
Old October 14th, 2015, 07:44 AM
They should be considered as a service item with limited lifespan and replaced periodically.
The question is what is the safe service life?
I'm thinking ten years or 120,000 miles based solely on my D1 experience.
Old October 14th, 2015, 07:49 AM
Pull 'em and forget all the madness.
Old October 14th, 2015, 05:26 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I retired my 1991 RRC to the junkyard last year with its original oil cooler lines intact.
Still had the little metal date bracelets on them.
23 years old and 145,000 miles and no oil fires---though I wished for one more than once.
Rent my
Old October 14th, 2015, 06:06 PM
Departing90
Sasha
95 D90
There's a reason why manufacturers use oil coolers at extra expence!
An engine that everyone can relate to........the V8 in the Disco II
LR in their wisdom decided to do away with the oil cooler on some years and the owners paid for their mistake in spades! All manner of engine issues resulted from the outcome including excessive heat & excessive lifter noise, lower oil preasure etc... installing a factory oil cooler and lines from a different year Disco II cured it permiantly!! I even install oil coolers on engines that didnt come with it or bigger ones on ones that did!
Old October 14th, 2015, 07:24 PM
Dee9tee's Avatar
Dee9tee
Steve Anderson
1997/D90
I recently installed the Trailhead cooler lines while performing the 60K maint on my 90. Not cheap but I was very pleased with the quality. Replacement was pretty straightforward and painless. Worth it for the peace of mind - the original lines, nearly 20 yrs old, were ready for the bin.
Old October 14th, 2015, 07:33 PM
Weldon's Avatar
Weldon
Weldon Pundt
"95" D-90
Thanks to all. I was able to reach Trailhead.
My lines were original, 198+++ miles. Popped like a pumpkin from a three story drop. And yes, lucky no fire.
Weldon
200tdi oil cooler / oil cooler line thread question dave_lucas Defender Technical Discussions 7 September 26th, 2012 11:56 AM
stock adapter between oil cooler and oil cooler lines dave_lucas Wanted 3 December 23rd, 2009 03:33 PM
Best Place for the Oil Cooler line upgrade parts rlynch356 Defender Technical Discussions 16 February 18th, 2009 01:54 PM
Oil Cooler Line Upgrade 1994 D90 SPIKE Defender Technical Discussions 16 October 15th, 2008 04:08 PM
Oil Cooler Hose Upgrade JimC Misc. Chit-Chat 6 October 15th, 2004 02:13 PM
