Upgrade Oil Cooler lines - Page 2 - Defender Source
Old October 14th, 2015, 07:35 PM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
Disco 1: 100k 18 years no problem
D90 80k 16 years oil line blew
I'd say lines need to be replaced every 10 years or 75k.
MonLand
1995 D90 NAS
1996 Discovery NAS
Old October 14th, 2015, 08:20 PM
Roverdoc's Avatar
Roverdoc
Dan Kemper
1997 D90 SW #278
oil cooler lines
I am have been running the trailhead lines for 5 years now. Recently went through an engine rebuild to a 4.6. Lines re installed and leaking. Removal and inspection revealed the o rings at the radiator adaptors were worn out. Beware. Quick run to the hardware store, new o rings and good as new with no leaks. I have run my prior rover without oil cooler lines with no issues. Replace or remove. Probably doesn't matter.
Old October 20th, 2015, 09:52 PM
Weldon's Avatar
Weldon
Weldon Pundt
"95" D-90
Once again, thanks to all.
Trailhead4x4 oil cooler lines are on there way.
Thanks.
Weldon
Old October 20th, 2015, 10:29 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Next time I drive for a while I'll measure incoming and exit temps of the cooler-- see if it is doing anything. Assuming it is doing a decent job, I'd say keep 100%. Otherwise, makes you wonder. Lower temp the better though... Maybe not for 100k, but what about 200k or more? Temp makes a difference-- hard to argue any different. But how much of a difference is the cooler making? I'd be curious to know...
Old October 20th, 2015, 11:53 PM
Departing90
Sasha
95 D90
A 3.9 Rover with the coolant @ 200 without a oil cooler. The oil temp was 242
Old October 21st, 2015, 12:32 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
good to know! Measure the pan? or where is that temp from? I'll measure my pan and intake/exhaust hoses from the cooler. Be good to know the temps as there is a lot of conjecture around this topic with very little other than a "mine has failed/not-failed" I'd find the data intersting--my guess is that it would be relevant to a break down in gear oil more than metallurgy... I'm on the fence as a lot of folks I respect don't use one...
Old October 21st, 2015, 02:01 PM
Departing90
Sasha
95 D90
The hottest part of an egine is the part furthest away from the radiator & oil cooler. In the case of the Rover V8 it would be cylinders # 7 & 8. In that area the hottest part is toward the top the the cylinder head meets the block so thats where you would measure. You can add around 20 to that reading depending on the ambient temp but more importantly because the head espetially being aluminum acts like a huge heat sink thereby disturbing the true oil temp reading.
Heat by a clear mile is the #1 enemy of an engine. When an engine is designed many specs are factored in with some being the correct heat range s plugs, radiator size and oil cooler size. The necessary parts go accomodate these specs are chosen from a parts bin or designed to accomodate them. Point being that engines are designed to operate ideally at a certain temp and reasonably well slightly below and above that.
Manufacturers dont provide unnecessary data such as oil temps without cooler and the CFM rating of the fan when the fan clutch is engaged or the fac service manual would be 3K pages long.
Personally I respect a lot of the members here and find their posts informative and enjoy reading them hence my post count since 06. There are a lot of misconceptions on this forum such as the oil cooler and oil pump priming procedure. At the expence of sounding sarcastic & you'll forgive me if I do is one to believe that LR would add a needless costly oil cooler if the engine didnt need it or techs are running around the factory with industrial size containers of lavender scented baby Vaseline to prime brand new 3.5 / 3.9 oil pumps or sticking a chop stick in cylinder # 1 to find TDC! I dont know where these misconceptions are rooted in but they seem to grow like wild fire on forums.
In several race applications techs will do away with the radiator fan for its hp robbing attributes but keep the oil cooler. My take on this is from what ive personally seen and experienced with oil coolers. Ive seen countless engines fail that dont have them and many that provided excellent longevity and more importantly running correctly with the ones that do or have upgraded oil coolers.
Hope this helps........
200tdi oil cooler / oil cooler line thread question dave_lucas Defender Technical Discussions 7 September 26th, 2012 11:56 AM
stock adapter between oil cooler and oil cooler lines dave_lucas Wanted 3 December 23rd, 2009 03:33 PM
Best Place for the Oil Cooler line upgrade parts rlynch356 Defender Technical Discussions 16 February 18th, 2009 01:54 PM
Oil Cooler Line Upgrade 1994 D90 SPIKE Defender Technical Discussions 16 October 15th, 2008 04:08 PM
Oil Cooler Hose Upgrade JimC Misc. Chit-Chat 6 October 15th, 2004 02:13 PM
