Upgrade interior lighting - Defender Source
Old July 5th, 2012, 07:32 PM
pdella
Paul
1997, Defender Alpine White
The dome light in my '97 is practically nonexistent and it is also nearly impossible to see behind the rear seats. I have been researching how to fix the issues- saw 2 options, any other/better ways to solve the problem?
Replace the current bulb with 4410-x9 Festoon 6 LED from www.superbrightleds.com
It isn't entirely clear that that is the correct bulb- is it and does it just plug into the existing bulbs place?
http://www.superbrightleds.com/cgi-b...on_4410-x9.htm
#2 was to buy a battery operated LED dome light and Zip tie it to the roll bar behind the front seats
Thoughts?
Old July 5th, 2012, 07:39 PM
ST or SW?
Old July 5th, 2012, 08:10 PM
Ray_G's Avatar
Ray_G
Ray Gerber
My Disco's a different application and I imagine your dome light is slightly different but a Rover's a Rover so it likely has similar properties. I have these in my Disco's Front/Rear dome:
http://www.amazon.com/gp/product/B00...ls_o04_s00_i00
Dirt cheap, easy to instal, and bright as hell.
r-
Ray
Old July 5th, 2012, 08:29 PM
pdella
Paul
ST thanks!
Originally Posted by Rocky View Post
ST or SW?
------ Follow up post added July 5th, 2012 08:32 PM ------
Im unsure if the Disco is the same dome light as the 97 ST defender?
r-
Ray
Old July 5th, 2012, 08:47 PM
Ray_G's Avatar
Ray_G
Ray Gerber
Originally Posted by pdella View Post
ST thanks!
Me too...does it look like this: http://www.ebay.com/itm/Discovery-Se...sories&vxp=mtr
If so...the amazon setup works. Bright enough that my fiancee is now annoyed with how bright it is when the doors open.
Old July 5th, 2012, 09:34 PM
pdella
Paul
Too big- mine is smaller!- bummer!
Old July 5th, 2012, 09:36 PM
pdella
Paul
My dome light- smaller that the Disco- mine is a ST!
Name:	Dome light Def.jpg
Old July 5th, 2012, 11:14 PM
I did the superbrightleds.com in the front/back of the 110, made a huge difference...it isn't cheap, but is worth it.
Old July 5th, 2012, 11:22 PM
pdella
Paul
Is it the same bulb in 110 as in '97 ST?
Old July 5th, 2012, 11:30 PM
Affirmative, and it was this one:
* *2 | 3710-xHP6: 6 High Power LED Festoon Bulb | *$ 14.95 |
* * * * *3710-WWHP6: Warm White
Old July 5th, 2012, 11:45 PM
pdella
Paul
Ordered- Thank you!
Old July 6th, 2012, 09:05 AM
I'd look to add some led strips wired tied to the roll cage and wired to that feeble excuse for a light.
dome light, ht, interior, led lights
diameter/thread of sending units for gauge upgrade jaherring Defender Technical Discussions 3 September 29th, 2005 05:14 PM
Suspension upgrade Rover- Girl Misc. Chit-Chat 41 September 12th, 2005 02:07 PM
OME upgrade advice kolvedic Defender Technical Discussions 11 August 16th, 2005 11:08 PM
Turbo/Supercharger upgrade advise needed babushka99 Defender Technical Discussions 2 October 16th, 2004 08:26 PM
Upgrade pushed back chrisvonc Misc. Chit-Chat 0 May 15th, 2004 11:23 AM
