UPDATE - Disco Truggy - Defender Source
Old May 21st, 2006, 01:10 PM
DiscoDino's Avatar
DiscoDino
Nadim Samara
1992 Disco "Dino"
Well,
Had a 3 day trip back to Lebanon to work on the truck and we are 80-85% done so far - only things to do is finish (1) the exo cage, (2) clean up the wiring, & (3) figure out the air filter/snorkel bit. All the new components are fully functional (4.2, Auto, underdrive, new brakes, Saginaw PS pump, 120amp, paint, waterproofed cab, interior, etc...)
Here are some updated pictures.
1. You're going to laugh, but we found this hydro manual bender in an adjacent garage. No markings, but it did bend the 60mm x 5mm tubing fairly easily...
2. Tidied up the front end and made a hood-attached radiator grill that came out looking "hereditary" from a RR Sport - all lighting will be Defender based for ease
3. Dual Yellow-tops slapped right behind the seat
4. Tiny rear window is all we need to look out of the truck (VW camper source)
5. OK, the trophy. My mechanic called me up (I like out of country) and told me "I found this big ass PS pump, I want to try to mount it, its cheap and looks huge" - after knowing that it has a built in metal reservoir, I know it was one of those desirable ones. It was tricky to mount as the belt needed to clear the box, but it is doable. I'll attest to 0psi in the 42s, on garage floor and steering, at idle, with one hand
6. Approach angle is more than I wanted, but it is not as bad as it seems. There will be a stinger there in upside down "U" form (not "V" as the idea is that the "v" one will make the truck rotate to the side - not sure how viable that is). I replaced the Warn 4-pack solenoids with a single Albright sealed solenoid - one each per winch.
7. The inside lost the A/C but I left the heater for now for the winter and defogging the glass. The rear glass is tiny, so no structural strength lossed. Also, the underdrive level is set (rod, no wire)
8. The rear section is taken up mainly by the stock fuel tank, but it’ll also have place for the 60” hi-lift, Pull-pal, Waffles, and a storage area for my tools and recovery gear. Also a place for my scuba tank air source
9. Here’s mocking up the exo cage – in fact we’ve already finished the trickiest bar (top one) and are finishing the “main” cage by Tuesday and hopefully by Saturday we should be fully tacked in. Next week we’ll get it fully welded, epoxy painted (rubbery stuff, real durable and cheap), and then remounted for chassis welding.
I really want to extend the wheelbase eventually (next spring) – I’m getting married and moving to the US, so no use in investing more into it now…also thinking of putting some Mog U1300s on it (1100 USD for a pair, 1200USD if they are both steering) while I’m at it…
Any suggestions? Comments? Let me have it while I can change for the last week.
Main think that’s puzzling me, how to mount a snorkel WITHIN the cab area (not outside the Exo) in an easy manner? Also, so I really need a snorkel? The hood is chest level, and I don’t think I’ll be flogging it in deeper muck/water? An open cone Filter would do?
'92 Disco truggy (42"s, ZF, dual cases, ARBs, 30 splined, OMEs, Optimas, Warns, Bead-Locked)
'04 D-90 TD5 ST (33"s, tuned, caged, 1/2 top)
'84 Rangie 2 door classic (32"s, OME, ARB bar & M8000)
'04 Disco II stock
'07BMW G650X Challenge (farkled)
Old May 21st, 2006, 09:50 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
That looks great. Thanks for sharing it with us! I do have a comment, when you come here, can you please bring 2 extra U1300s for me? I pay cash! Now finish this already and get some action shots!
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old May 22nd, 2006, 01:03 AM
DiscoDino's Avatar
DiscoDino
Nadim Samara
1992 Disco "Dino"
Disc or drum ? trying to finish it so that I can wheel it by beginning June!
'04 Disco II stock
disco
D-90 1994 parts and Disco 2 parts JAD For Sale - Parts 10 August 1st, 2006 03:00 PM
01 Disco! TwisteD90 For Sale - Vehicles 4 February 7th, 2006 01:38 PM
Help empty my garage! Ton's of parts.. RedRhinoProducts For Sale - Parts 12 June 1st, 2005 09:24 AM
Garage Sale - 2ea LT-230, Hood.... RedRhinoProducts For Sale - Parts 10 November 22nd, 2004 08:12 AM
97 trans/xfer into 95 Disco boxerhips Defender Technical Discussions 4 June 10th, 2004 01:08 AM
