Unusual tire wear - Defender Source
Old August 24th, 2015, 12:38 PM
PabloCocito's Avatar
PabloCocito
Pablo Cocito
1987 Defender Tithonus
Hey guys, so today while turning in a tight circle I noticed a rubbing like sound from my front right tire, when I went to check I noticed that the front right has a weird wear on the inside. Anyone know what this could be??
Old August 24th, 2015, 12:39 PM
The Dro
Dro
1988 Ninety
adjust the steering lock stop
------ Follow up post added August 24th, 2015 12:41 PM ------
Defender 90 XS: Steering Lock Stop Adjustment
Also check the track rod and drag link. They bend very easily.
Old August 24th, 2015, 12:45 PM
aka steering stops. You're likely rubbing your radius arm(s).
Old August 24th, 2015, 12:49 PM
PabloCocito
Pablo Cocito
I checked for rubbing and there is no rub marks anywhere. And I also checked all the rods and they're all straight.
It seems to be like a road contact issue.. Could it be something with the diff?
------ Follow up post added August 24th, 2015 10:54 AM ------
It's also the top of each knob that is worn, the bottom ones are okay.
Old August 24th, 2015, 12:54 PM
Check your alignment.
Old August 24th, 2015, 01:58 PM
Wear pattern you picture is known as cupping.
Rotate those tires to the rear asap or wear them out and get better tires, G90 is a horrible tire.
Alignment is off.
7.50's shouldn't rub anywear. Are you certain your difflock is fully disengaged ?
Old August 25th, 2015, 02:52 PM
PabloCocito
Pablo Cocito
It seems to not be doing it anymore, I engaged and des engaged the diff lock and reversed a bit and it seems to be back to normal.. Could I have done any damage to the drivetrain by driving it like that?
Old August 25th, 2015, 03:07 PM
Nothing to worry about.
Unusual Roverlab Misc. Chit-Chat 12 August 22nd, 2014 09:14 PM
LR3 tire wear settlement nathanwind Misc. Chit-Chat 3 December 25th, 2013 09:03 PM
Unusual lamp guards kevincdoyle Defender Technical Discussions 11 November 28th, 2013 01:48 AM
Curing mud tire uneven wear winn442 Defender Technical Discussions 2 April 11th, 2013 10:26 AM
Unusual oil pressure readings. bomilcar Defender Technical Discussions 3 October 30th, 2007 05:53 PM
