Unusual oil pressure readings. - Defender Source
Old October 30th, 2007, 09:39 AM
bomilcar's Avatar
bomilcar
Stephen Miller
73 Series III Orig Owner
I installed an ISSPRO electronic oil pressure gage about 6 months ago. #R5621R http://www.egauges.com/vdo_ind.asp?T...VA_R&PN=R5621R
It has a sending unit that runs to a module that connects to the gage. Seemed to be running correctly; 8-10 psi at idle and 35-40 psi at 2000 rpm. A week ago it developed a mind of its own. Instant and dramatic changes in pressure reading. All to the very high end. Pegged the gage frequently. Never went back to the 6-10 psi range. No real clear correlation to rpms. Sometimes idle at 40 psi some times at 60 psi. Checked the pressures with a shop gage and found the pressures to be with in spec. Before I pull the entire unit I thought that I would see if anyone has been down this road before and might give me some guidance.
Steve
Steve
73 Series III (Original Owner)
94 D-90
2011 LR4
"anything that can go wrong has"
Old October 30th, 2007, 12:22 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Sounds like it's grounding out somewhere, I'd look for a loose or chafed wire. Either at a connection or possibly where the wire passes through the firewall.
-Hans
My oil line fix
My 100k stopped odometer fix
Old October 30th, 2007, 12:42 PM
bomilcar's Avatar
bomilcar
Stephen Miller
I will check them out
Steve
94 D-90
2011 LR4
Old October 30th, 2007, 05:53 PM
bomilcar's Avatar
bomilcar
Stephen Miller
Pulled new wire from sender through module to gage; same symptoms. Guess it is new unit time.
Steve
94 D-90
2011 LR4
low oil pressure at idle--sometimes cpk Defender Technical Discussions 5 February 7th, 2006 01:10 AM
1995 d90 no oil pressure bmwfastlyf Defender Technical Discussions 3 January 18th, 2006 03:10 AM
Oil pressure gage rover4x4 Defender Technical Discussions 4 November 30th, 2004 09:44 PM
