Until I swap engines to an EFI... - Page 2 - Defender Source
Old November 30th, 2014, 10:10 PM
LRover's Avatar
LRover
J. Michael McCaig
I too am running a 4bbl manifold and the edelbrock 500cfm carb on my V8 and am very pleased with it. it was a fairly straight forward conversion.
Old December 1st, 2014, 07:52 AM
Firemanshort's Avatar
Firemanshort
David Short
1980 Stage One 109
Regarding the vent tubes from the valve covers - each side runs up to a "y" and then the single line plugs into the rear of the air cleaner assembly (not the carb itself). You may need to buy the "Y" and some generic vacuum lines - but it all standard auto parts store stuff.
Any old round air filter works. They are really cheap. You just need to match your air cleaner size. McMike has a sophisticated engineered air cleaner and I just run the standard 11 inch Edelbrock. We both seem to do ok.
I double what Doug said about getting newer EFI heads with a better compression ratio.
As far as tuning - I tweaked my carb (Edlebrock 1404) with different needles and jets until I was blue in the face. I was never able to generate a significantly better result than the way it was tuned out of the box new (but I was able to do worse).
The only problem I have is when I go off road and drive at severe angles. The carbs do not run well when tipped - even with the special off road floats and springs installed. Once you get back level - everything is fine again.
Firemanshort
1980 Stage One 109
Sterling, VA
Old December 1st, 2014, 09:15 AM
LRover's Avatar
LRover
J. Michael McCaig
"Sophisticated engineered air cleaner" That's being generous for sure! It's a peanut can turned upside down that just happened to fit the carb. I didn't have room for a standard air cleaner so necessity became the mother of invention.
I played with re-jetting the carb but, like David, I didn't have too much luck and went back to factory specs. Adjusting the float level helped a lot on the off-angle trails but I swear the old dual carb setup would run upside down...just didn't run well on the flat!
engine
FREE Blockbuster night until the end of the year. themaxx Misc. Chit-Chat 5 November 10th, 2007 09:24 AM
$100 off instantly at Discount tires until Oct 20th themaxx Misc. Chit-Chat 2 October 19th, 2007 04:19 PM
You're not really a Defender owner until... Ragland Misc. Chit-Chat 14 April 1st, 2006 08:39 AM
Can't Wait Until I get My Hands On The Wizard Defender Technical Discussions 6 February 13th, 2006 09:03 PM
How long until you see a D-90 like this? Trigger Misc. Chit-Chat 4 June 30th, 2005 02:12 PM
