universal joint identification help - Defender Source
Old January 18th, 2014, 10:00 AM
myoverlandrover's Avatar
myoverlandrover
josh
109
Trying to replace u joints in acquired drive shafts (not sure what year) and bought moog 369 but they are two long 82mm. The ujoints I took out say "GKN 9J" and measure roughly cap to cap 77.5mm but i had to beat it out pretty good so might be a tad off. Trying to source some locally today at local parts stores...any help?
Defender 110
Old January 18th, 2014, 10:05 AM
what year 110, I think they changed them at some point. NAS trucks take a precision 344, Im not up to speed to the grey market junk
Old January 18th, 2014, 10:26 AM
TeriAnn's Avatar
TeriAnn
Teriann Wakeman
1960 Dormobile
GKN is not a junk aftermarket brand. The are a well respected mainstream brand. I currently have at least a pair of them under my truck that I purchased off the shelf at a local California auto parts store.
TeriAnn
Old January 18th, 2014, 11:29 AM
I'm pretty sure the Precision 344s are for 90s only, if I recall the 110 UJs are different spec.
Old January 18th, 2014, 11:34 AM
i wasnt bashing GKN
Old January 18th, 2014, 11:46 AM
myoverlandrover
josh
109
As put in my post I don't know what year the shafts are. 344 matches up to over all size to the GKN but does have a slightly longer cap that I hope is ok.
Defender 110
Old January 18th, 2014, 11:47 AM
Grover's Avatar
Grover
Car Quest carries GKN.
Old January 18th, 2014, 11:50 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
The bearing cap diameter is also needed
Old January 18th, 2014, 11:53 AM
myoverlandrover
josh
109
I did confirm it's the same to 344 in the store. I'll post up soon confirming they installed ok.
Defender 110
Old January 18th, 2014, 03:19 PM
myoverlandrover
josh
109
Confirmed gkn 9j / gkn9j is moog or precision model 344 universal joint.
Defender 110
Old September 22nd, 2014, 11:54 AM
tgraham's Avatar
tgraham
Travis Graham
1994 Defender 90
Heads up: I ordered some Moog/Precision 344 U-joints from Amazon... the fit looks correct, but the grease screw is on the top/bottom (at least, on the units that I received), which does not work.
Travis
Old September 22nd, 2014, 12:20 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Originally Posted by tgraham View Post
Heads up: I ordered some Moog/Precision 344 U-joints from Amazon... the fit looks correct, but the grease screw is on the top/bottom (at least, on the units that I received), which does not work. Travis
what do you mean top/bottom?
Jimmy Buffett
Old September 22nd, 2014, 12:28 PM
tgraham's Avatar
tgraham
Travis Graham
1994 Defender 90
I suppose top/bottom isn't the best description, maybe "longitudinal axis" as it would be once installed. See attached illustration.
Travis
Old September 22nd, 2014, 12:41 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
Ha! That's interesting. Have fun greasing those!
Old September 22nd, 2014, 12:54 PM
what UJ for NAS 110's?
Mark Kellgren
KM4BOR
Old September 22nd, 2014, 01:05 PM
There are two sized joints used in Defenders.
1310 Series, 5-153x: 27 x 81.8 mm They started using these in the series 2a? and into early 90/110 production.
1300 Series, 5-4x: 27 x 74.6 mm. Everything after the early ones and I think before Series 2a.
Just quickly measure the length between caps to tell which one. It is over a 1/4" difference, so hard to mix them up.
Old September 22nd, 2014, 01:18 PM
I've used the Precision 344s, and previously they had them in the "Y" (not where you pictured). That is odd they'd change them. Also remember you need to (with the zerk in the Y anyhow) orient the zerk so it is under compression when the driveshaft spins (versus pulling away from the zerk).
Old September 23rd, 2014, 12:13 PM
flippedrover
Tyler
'94 D-90
actually really easy greasing those. My front shaft has that type of U joints and it's been easy to grease.
Jimmy Buffett
Old September 23rd, 2014, 01:11 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Do yours have a 90 zirk fitting ?
Old September 23rd, 2014, 01:50 PM
I have had a number of custom shafts made recently for 110 auto conversions and I drop the old rover shaft off with UJ's that are fine and the dude puts new ones in as a matter of practice ea time. He's installing Spicer 5 153x joints and charging me $8.80ea fwiw. I see John has nailed the fitments.
List price for the Spicers is $14.08 ea.
Hope that helps someone out.
Rear Wishbone Ball Joint Assembly, Tie Rod End & Drop Arm Ball Joint Rebuild Kit BMGmotors Defender Technical Discussions 18 June 27th, 2011 01:59 PM
Rear Ball Joint Buckon37s Wanted 4 April 9th, 2006 06:54 PM
CV joint gone bad? Hans Defender Technical Discussions 5 December 4th, 2005 04:24 PM
Rear A-arm Ball Joint ronward Defender Technical Discussions 4 February 25th, 2004 08:53 AM
rear ball joint mattdh Defender Technical Discussions 3 October 13th, 2003 04:28 PM
