Unique NAS/ROW soft top hoop set combo - Defender Source
Old June 3rd, 2016, 08:35 PM
vtlandrover
Frank
1991 200Tdi 110 Hicap
This is from an ebay ad... it seems to be a combination of the original NAS roll bar + the forward portion of ROW hoop set drain channels... wonder if anyone can point me to the parts involved and - most importantly - if it would help support the forward portion of my Tickford top.
The reason for the support: I've posted a few times over the last two years requesting measurements of the metal support bar that runs through the very front of the Tickford (where the soft top slips into the channel above the windscreen). As it seems to be an unavailable part, I am thinking this will help keep the top from "buffeting" at highway speeds and popping out of the channelling... a major PITA.
http://i.ebayimg.com/images/g/pdIAAO...~i/s-l1600.jpg
http://i.ebayimg.com/images/g/kiEAAO...~c/s-l1600.jpg
Old June 3rd, 2016, 08:36 PM
That bar is just a piece of flat stock. Go to Home Depot and see what fits inside and paint it and cut it to length.
Old June 3rd, 2016, 08:57 PM
Are you talking about the gutter kit? Badger sells/sold them.
Old June 4th, 2016, 07:41 AM
vtlandrover
Frank
I have an aluminum piece of flat stock in place... it still pops out. I've tried to locate slightly thicker and/or slightly wider material, but haven't found success - so I'm going to resort to having the local machine shop cut me both options and see which shape holds the top in place.
Regarding the gutter kit, thanks for the direction... I'll try to get in touch with Chris.
Old June 4th, 2016, 08:00 AM
Nooner's Avatar
Nooner
Ryan Noonan
1994 D90 NAS #159
Are you talking about he horizontal bar that slips between the windscreen and roll cage that the soft top snaps to and the door seals against?
http://www.badgercoachworks.com/inde...s/Page1431.htm
$125 for the pair from Badger
Old June 4th, 2016, 08:23 AM
vtlandrover
Frank
No. It's a piece about 4' long that slides into a slit in the canvas - from the passenger side - and runs the length of the windscreen at the forward-most part of the Tickford top.
Regarding Badger, I've tried a coupe of times over a couple of years... no follow-up, although he's mentioned having them in stock and would let me know. Thus, my reason to reach out to the forum for measurements. Still no success - probably because it necessitates taking the top off altogether to measure.
hoop, nas, soft top, top
Full soft top (hood) w/ hoop set for 109 greenmonster For Sale - Parts 1 March 14th, 2016 02:29 PM
Wanted: ROW Soft top and Hoop set. RX6RCROL Wanted 1 May 19th, 2014 09:51 PM
series 3 soft top and hoop set mountainviewrover Wanted 2 November 29th, 2010 07:30 PM
row hoop-set and top mightymg Wanted 8 November 18th, 2010 11:31 AM
110 / 90 ROW Soft Top Hoop Set SafariHP The Vendors Loft 11 February 9th, 2009 06:08 PM
