unidentified engine component '88 110 V-8 - Defender Source
Old April 23rd, 2013, 12:13 AM
akrockhound's Avatar
akrockhound
Jack
1988 RHD 110
Name:	engine compartment.jpg
Folks - Can anyone identify this engine component in the attachment. There is one on either side of the 3.5 V-8 in this '88 110. I have been told its "something to do with emissions" but no more details than that.
Old April 23rd, 2013, 12:32 AM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Do you have a wider photo ?
Old April 23rd, 2013, 02:06 AM
CDeWan
Clay DeWan
5.3L beastie
Is it hooked up to the exhaust it looks like an exhaust recirculator.
Old April 23rd, 2013, 02:54 AM
Tophat
Oliver
All sorts of Defenders
It is a sort of a cleaner emissions trick of Land Rover.
I have allways taken the whole thing out, blank the 2 openings where the hose fits on the airtube between the carbs and the airfilterbox, and blank the holes where the thing fits in the heads.
The steal tubing tends to rust near the head which gives you an extra exhaust blow, and the gurgling sound from the airfilter goes away.
110, engine
Engine Proble: Please Advise saber6 Defender Technical Discussions 24 November 6th, 2009 10:06 AM
Fault Code 48/fast engine idle speed arbik Defender Technical Discussions 9 June 2nd, 2006 07:02 AM
???still can't get the trany unbolted from the engine???? kit Defender Technical Discussions 4 October 23rd, 2003 03:20 PM
Why can't I disconect the engine from the trany? kit Defender Technical Discussions 6 October 22nd, 2003 07:40 PM
