Uneven treads - bad for the diffs? - Defender Source
Old November 8th, 2012, 04:01 AM
sro
Sam Odio
2008 LR2
So, I have a set of 3 tires with about 50% of their tread left. The fourth punctured and was un-reparable. I'm running with the spare (100% tread) on that tire.
So my question is: how worried should I be about this tread mis-match? I'm not too worried about it in 4x4 mode (since I only lock the diffs when conditions are loose)...but what about highway miles?
Old November 8th, 2012, 04:23 AM
Not something that would worry me
Old November 8th, 2012, 10:38 AM
sro
Sam Odio
2008 LR2
Wow, ok. Even with highway driving? Good to know, thanks.
Old November 8th, 2012, 10:55 AM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
4x4 mode??
Measure the diameter of the two different tires.
Old November 8th, 2012, 11:07 AM
the differential allows the 2 wheels to rotate at different speeds ... this is normal behavior for turning a corner ... or if the tires are running slightly different pressures ( bad for other reasons )
I would worry more about the different levels of grip by having mismatched tires than wear on the diff.
I would suggest having 2 100% tires on an axel.
Old November 8th, 2012, 01:26 PM
sro
Sam Odio
2008 LR2
Interesting. I also thought that I should try to get both tires on the axel to have the same tread, but more for the axel's differential wear. I'm really just not sure
Why are you worried about different levels of grip?
Old November 8th, 2012, 01:28 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Hard braking on a wet road without ABS...
Old November 8th, 2012, 01:30 PM
sro
Sam Odio
2008 LR2
Fair enough.
Old November 8th, 2012, 01:40 PM
Howski's Avatar
Howski
Kevin
2002 Land Rover Discovery II
And move one of the 50% tires to spare duty
Old November 8th, 2012, 02:10 PM
sro
Sam Odio
2008 LR2
That's what I'm going to do, since the new spare (and the old spare) both have close to 100% tread.
I just wanted to make sure I understand why that's important. Sounds like it's more about handling than saving the differential.
Old November 8th, 2012, 03:04 PM
sro
Sam Odio
2008 LR2
Also, should the newer tires go on the front in the back? Any ideas?
Old November 8th, 2012, 03:05 PM
Craigd's Avatar
Craigd
Craig Dickson
1995 D90 Red Soft top
Totally unrelated vehicle but my sister had an Olds Bravada and she developed some transfer case problems because she was running two slightly different sized tires.
Old November 8th, 2012, 06:00 PM
I would put them on the front personally to avoid aqua plane risk. Losing the front is worse than losing the back IMHO.
Old November 8th, 2012, 06:27 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
I recently heard that the newest tires should be put in the rear to avoid breaking loose and fishtailing. I have no evidence to back this up though.
I put my fifth into the rotation so they should all be about the same for wear.
Old November 8th, 2012, 07:27 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
When I decided to use my new spare (NOS), buy 3 new tires, and rotate an old worn tire into a spare, this was my problem. The old spare (BFG AT/KO) was about 2" shorter in diameter than the 3 new I'd purchased. The NOS tire ended up on the RR location and because I run a Detroit locker in the rear diff, about every 1/2 mile the diff would unload with a noticeable jerk going down the highway. I ended up rotating the NOS tire to the front axle, problem solved.
Old November 8th, 2012, 07:32 PM
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
Im not one for rotating the spare tire in. If i have an issue with one of the tires, i get it fixed and i don't worry about the uneven tread for the maybe 50 miles i drive on it while the tire is being fixed, if getting fixed is not possible i buy another new tire and move a worn tire to the spare.
Old November 8th, 2012, 10:23 PM
bossman429's Avatar
bossman429
Adrian
1988 90
This is the accepted standard for tire shops bc most people don't know what to do in an oversteer situation. Therefor, you can't rotate tires on a fwd car I disagree with this as the front tires are more important to braking and turn in than the rear,which is usually the two things you do in an emergency. Plus, I know a thing or two about car control.
Put the new in the front. As the fronts wear quicker anyways
Old November 9th, 2012, 07:13 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
If you do not have the spare in the rotation schedule on your truck I would not use it other than a spare to use to get me home. If you read the manufacture websites on "all wheel drive" trucks/cars they recommend that all four tires be the same size and tread. A small difference in wear is acceptable but a large difference may cause problems. If you think about how your transmission, transfer case and axles work in switching power to one wheel that has the grip you can understand how a tire with better traction can change the handling behavior. This may not be a dangerous situation but your truck may not handle as well as it could. As mentioned above you can also have some wear issues on the running gear. I personally leave the spare as that until I get ready to get new tires and then get three and use the spare as the fourth.
Land Rover 110
diffs, fs
Symptoms of a bad axle CV joint? Hans Defender Technical Discussions 16 April 6th, 2007 01:20 PM
Need Help For Bad Handling...(I mean BAD!) Cube II Defender Technical Discussions 18 July 7th, 2006 09:07 AM
detroit diffs, shafts, AEU2522 conversion SeaRover For Sale - Parts 5 February 27th, 2006 09:34 AM
bad bad BAD noise rover4x4 Defender Technical Discussions 11 December 12th, 2003 12:44 AM
Mobil 1 in the diff's rover4x4 Defender Technical Discussions 2 November 14th, 2003 10:48 PM
