Underhood winch controller box installs - Defender Source
Old September 25th, 2013, 12:46 PM
We are installing an m8000 in an original 90/110 winch tray on Trey's 110. The controller plug will be relocated to the grill surround hood lock hole on his 83. Where have others located the solenoid box ? On a tdi the choices are easy, on a V8 not so much. Either way it looks like custom long positive and negative cables are going to be required.
Looking for ideas as to what others have done and comments on what you like and don't like about what you have done.
Old September 25th, 2013, 01:23 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Doug, I mounted the solenoid box in my Hunter inside the engine bay in the 2nd battery box area. I left the remote plug on the box as well.
I'm sure you'll have a little more room to work with on the 110.
Mock it up with some scrap wire, then get some cable when you know how much length you'll need.
Rent my
Old September 25th, 2013, 01:31 PM
I would be inclined to leave the lock in place. It acts as a safety if the latch comes undone on the hood. What is wrong with the original NAS location for the solinoid box on the top of the bumper? I am sure Josh can dig up a pic for you.
Old September 25th, 2013, 02:13 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
You're using an Albright solenoid, right? Take it out of the box and you'll have a lot more mounting options because of the reduced size. My Albright is installed behind my grill, next to the fans. The plug is mounted on the grill.
Obviously the Disco is different from the D110, but you get the idea.
Plug is behind the drivers side Hella.
Old September 25th, 2013, 02:35 PM
Doug, this is done on my 90...you should've mentioned it this past weekend! I can take some pics if you'd like.
Old September 25th, 2013, 02:56 PM
kinda hard to see by my controller is mounted behind the left headlight. with the remote connector in the headlight bezel.
Plenty of room under the hood.
ID:	80830   Click image for larger version
95' D90 - daily driver..
Old September 25th, 2013, 03:00 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Stock from the factory (or were these dealer installed?) or this under and upside down mod.
ID:	80843   Click image for larger version
Old September 25th, 2013, 03:02 PM
I'm actually in about the same spot for the solenoids, but my connector runs to the grill surround.
Old September 25th, 2013, 03:10 PM
Shep29's Avatar
Shep29
KS
'95 RRC LWB
I mounted mine to the inside wall of the left hand wing near the alternator. Annoying job but happy with the results.
'95 RRC LWB Aspen Silver
'86 110 SW Conniston Green - SOLD
'95 D90 ST Beluga Black - SOLD
'96 D1 SE7 Willow Green - SOLD
Old September 25th, 2013, 03:20 PM
jefferson's Avatar
jefferson
Jeff A
97 Defender 90 SW #593
I mounted my Albright under the hood, on the drivers side. There is a metal brace that the horns are mounted to (at least in my NAS) - if you move the horns around a bit, it provides a nice, accessible spot.
Old September 25th, 2013, 03:21 PM
i may reroute it through the grill - but i'm running the heritage grill so i would have to cut it and then worry about the wear on the cables. right now they are tucked tight between the frame rails.
Old September 25th, 2013, 04:35 PM
you are making assumptions about the condition of that lock. The only redeeming factor was the chrome was still good. Its in the rubbish bin.
Trey doesn't like that look with the box on the bumper- just like he doesn't like 5 bar anywhere, roof racks etc. Pretty friggin opinionated for a 19yr old.
------ Follow up post added September 25th, 2013 04:38 PM ------
Nicely done.
Old September 25th, 2013, 05:53 PM
Well Trey is running into an issue where the front radiator surround panel needs to be cut to accommodate one of the oe winch trays. I went back and every single one I can find a picture of is cut differently on 90's, presumably by the original dealer installers. Hate cutting a body panel even if it will be hardly noticeable, he wants me to do it.
Old September 25th, 2013, 06:38 PM
Surely there is a spare one about? Maybe a wrinkled EX-MOD one?
-Jeff
oh I have others...
This is Trey's 61,700 mile truck - not mine
Old September 25th, 2013, 10:01 PM
others were different colors and just as straight. Its cut.
Old September 25th, 2013, 10:18 PM
aclarke's Avatar
aclarke
Andrew Clarke
1986 110 CSW 200tdi
I kinda hate to mention this as I don't want to be the guy seen as bagging on others' work. I assume you have a winch cutoff switch somewhere, but if this was my truck I'd still be concerned about having my positive leads bolted just mm away from the inner fender.
Putting a rubber gasket or something like that in between the fender and the solenoid would greatly reduce the possibility that something could fall in there and create a short from those wires to the fender.
My solenoid sits proudly on top of my winch. I guess that's why someone at a mechanic shop thought it was a step and broke the cover box. I should probably relocate it some time but unfortunately I have bigger fish to fry at the moment.
Edit: Boots over the positive leads would accomplish the same end.
1986 110 CSW 200tdi (
Old September 26th, 2013, 02:01 PM
Gren_T's Avatar
Gren_T
Gren Thomas
1985 90 300tdi auto
Hi Doug,
I mounted the albright under the vent panel on the wing and secured it to the header bottle bracket.
At the same time I added a wireless winch remote, I did intend to add a hand socket but have not bothered as I can control the winch from the cab also.
regards
Gren
Old September 26th, 2013, 09:21 PM
No offense taken - actually i have been looking at that as a to do item. so far (50k miles or so) it has been no problem. I'm in the process of rewiring the accessories to a better standard. (not to mention my Negative cable is grounded to the chassis and i plan to run a cable to the battery compartment to remedy that.) I also need to separate the winch master switch from the main master switch.
That said the location is perfect and roomy to get your hands in there..
Old September 26th, 2013, 10:29 PM
You can always save the original and swap out for a different one.
Old October 2nd, 2013, 11:07 AM
Trey C
Trey Crowther
1983 V8 110 County
here is my finished install. This is the original bumper which was galvanized and had some tweaks in it that we straightened with the porta-power duck bill attachment. The winch controller plug is up by the Land Rover 110 decal.
We might eventually go back to galvanized but for now the satin black looks good. I like to clean look.
ID:	81358   Click image for larger version
hood, winch
WARN WINCH CONTROLLER MOUNTS- Three different styles- NashvilleRover For Sale - Parts 0 December 19th, 2011 11:23 AM
Moving Warn Winch Solenoid control box sundogcwolfe Defender Technical Discussions 7 May 20th, 2010 03:18 PM
Warn winch controller and/or complete NAS 110/94 D90 winch set up evilfij Wanted 9 October 7th, 2009 01:23 PM
Safari Gard winch bumper and winch m016324 For Sale - Parts 3 September 20th, 2005 09:52 PM
WARN 8274-50 Winch, THE ULTIMATE!!! RedRhinoProducts For Sale - Parts 0 September 28th, 2004 08:18 AM
