Underhood Insulation - Defender Source
Old October 14th, 2014, 09:52 AM
pitchrollyaw's Avatar
pitchrollyaw
wayne p
1985 d90 2.5NA
Anyone have any experience or thoughts on the various under hood acoustic insulation products, typically the self adhesive foam w/ foil types? this is for my 2.5NA.
My original under hood pad is crumbling away and a new one doesn't seem worth the shipping cost if there are better alternatives.
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
Old October 14th, 2014, 10:10 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
I put a heavy adhesive material, coated with what I believe is a sheet of lead under the hood of wife's D2 and I'm quite happy with te result.
It's not easy to apply, you have to the hood off, but the result is neat and it seems to be holding great.
Cheers
- Charles Eames
Old October 14th, 2014, 10:56 AM
87 D110 (Ruby)
Go to defenders northwest and buy their acoustic mat. Easy install, made for vehicles...helps a lot
Old October 14th, 2014, 11:06 AM
Dynamat hood liner is useless
Old October 14th, 2014, 11:37 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
The hood on a Def. comes off real easy. Remove the thing that holds the hood up (arm), then
Raise it straight up against the wind shield & lift, the hinge pieces separate from one another.
Old October 14th, 2014, 11:52 AM
the rover shop
shayne young
Contrary to what bill says I used the dynamat 3/4 inch and I think it worked great.. Just make sure you use the 3m super trim adhesive.. Sticks like shit to a blanket..
Old October 14th, 2014, 12:08 PM
richord
Richard Ordowich
1987/D90
I too used Dynamat on my 2.5 TD and found it works well. The only noises left are parts falling off the truck ��
Old October 14th, 2014, 03:53 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
This is what I've been using:
http://b-quiet.com/products-3/b-quiet-ultimate/
- Charles Eames
Old October 14th, 2014, 04:52 PM
Originally Posted by JFD View Post
For underhood? That would not work well there and it would get too hot.
This is what they sell for underhood: http://b-quiet.com/products-3/b-quiet-hliner/
Old October 14th, 2014, 05:44 PM
Jbullis's Avatar
Jbullis
Jason Bullis
1994 NAS 90 #1810, 2006 LR3
I spoke to Photographer for National Geographic at Expo a East that an awesome 300tdi 110, I noticed he used the DynaMat hood liner and said he has had awesome results with the product. None of the issues some others have spoke about. I just ordered a kit earlier today on Ebay for $49.21 shipped free.
http://www.ebay.com/itm/360886888864...witem=&vxp=mtr
Old October 14th, 2014, 06:49 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
Dynaliner is a sponge- and holds it weight in water many times over. This makes it a horrible hood liner for an offroad vehicle, fine for a garage queen.
Old October 14th, 2014, 08:29 PM
Lemonhead
TB
1997 D90 SW
I used the B-Quiet and noticed an obvious improvement in noise and heat.
Also - very easy to install and it has held up nicely after two+ years.
Old October 14th, 2014, 09:25 PM
Yup. Even when it rains it soaks in water. No idea how but it does. It's coming out. There's got to be a better thing out there.
Old October 14th, 2014, 11:30 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Originally Posted by Red90 View Post
For underhood? That would not work well there and it would get too hot. This is what they sell for underhood: http://b-quiet.com/products-3/b-quiet-hliner/
It's working like a charm in my case. They say you can use it under
the hood in the product description.
- Charles Eames
Old October 14th, 2014, 11:57 PM
I'm at that stage to. Any of you take DB readings before and after?
I see 92-96 DB regularly.
Old October 15th, 2014, 06:48 AM
Himalaya's Avatar
Himalaya
Mark WS
1995 Nas, 86 D110, 97 Hummer H1
Why don't you just use the actual factory bonnet pad
Old October 15th, 2014, 08:04 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
It doesn't age very well, especially if it get soaked.
- Charles Eames
Old October 15th, 2014, 08:19 AM
You're kidding of course
Old October 15th, 2014, 12:20 PM
Not if the smartphone app is to be believed.
Old October 15th, 2014, 12:51 PM
300tdi convert
Michael Giddinge
Late 80s 110 300tdi
It's one thing when your covering a 3.9, but what about noise reduction and heat protection with a 200tdi defender high mount turbo (not to mention my 300 tdi VNT which is up close to the hood). Recommendations/suggestions? Much more of a challenge than quieting a 3.9. If your concern is impact of water, what do you use and recommend?
hood
Underhood winch controller box installs Uncle Douglas Defender Technical Discussions 19 October 2nd, 2013 11:07 AM
wrapping exhaust manifold to reduce underhood temperatures. cdb Defender Technical Discussions 16 February 15th, 2012 12:24 AM
underhood cleaning rustydefender Defender Technical Discussions 11 July 9th, 2006 04:13 AM
Underhood illumination Trevor Tarr Defender Technical Discussions 2 June 30th, 2005 01:28 AM
Replace tranny hump insulation??? JRowe Defender Technical Discussions 8 October 16th, 2003 10:35 PM
