Underhood Insulation - Page 2 - Defender Source
Old October 15th, 2014, 01:54 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
I have Dynamat and Dynamat hoodliner on my hood and love it. Gets rid of that awful noise when you slam the hood shut too.
Old October 15th, 2014, 08:58 PM
pitchrollyaw's Avatar
pitchrollyaw
wayne p
1985 d90 2.5NA
Thanks all, appreciate the feedback. Hadn't thought about Hoodliner's sponge potential......
'85 90 2.5NA
'72 SIII 88"
Couple other cars
..tolerant Wife...
Old October 16th, 2014, 08:44 AM
cellulararrest
Chris Snyder
Really hasn't been an issue for me. The few times it has gotten wet it dries right out with all the heat.
Old October 16th, 2014, 08:57 AM
Noticeable difference then?yes I do see those DB numbers nothing but metal between and the drivetrain.
Old October 16th, 2014, 09:02 AM
BlackField's Avatar
BlackField
Oscar
D110
I have a 200TDi with the acoustic valve cover and 3/4 dynaliner and the extreme dynamite over the turbo. Works ok for me so far.
Disclosure: I failed to tighten my turbo down pipe properly and it came apart spewing hot turbo exhaust onto the dyna liner extreme. Some tar melting occurred but otherwise unscathed. I removed it put in a new piece of extreme and tightened my down pipe. tada.
Old October 16th, 2014, 08:00 PM
akrockhound's Avatar
akrockhound
Jack
1988 RHD 110
Don't rule this option out
Consider this
http://http://www.lowes.com/pd_15401...ductId=1018733
Its called peel n seal. At $1.25/square foot its worth a look. It is an aluminum backed butyl based product. I have used it on my footwells and seat box and floors with good results. It sticks great (even in the cold up here). At 6 inches wide its more work to cover large areas.
Based on the description of dynamat and BQ peel and seal looks like a cost effective alternative. Even if you put on 2 layers its still a fraction of the cost. You can buy it at Lowes
'88 ROW 110 5-door SOLD
'01 Disco II
'95 RRC LWB
Old October 16th, 2014, 09:36 PM
But have you tried it?
Old October 16th, 2014, 09:43 PM
akrockhound
Jack
1988 RHD 110
Yup
Yes,
I used it in my footwells, bulkhead, floors, tunnel and seat box, plus in the rear load area. I think its a good product. For $16 I suggest you pick up a roll at Lowes and decide for yourself.
I plan to use it under my hood but I want to do some corrosion abatement first. I have a 3.5 so its not exactly noisy compared to the road noise and drive train. Likely put it under my headliner too when I finally get in there.
Good luck
'01 Disco II
'95 RRC LWB
Old October 16th, 2014, 09:49 PM
At that price its worth it. Just checked out Dynamat shipping via amazon v Bquiet. There is no comparison. Bquiet shipping is as much as the product. Amazon prime makes the dynamat an easy winner. But at $16 a pop, this stuff seems to hit the price point that others will never reach.
Shame the Lowes link seems so flaky.
Jackie Treehorn's Avatar
Jackie Treehorn
A
1985 (legitimately)
Originally Posted by akrockhound View Post
Consider this
Its called peel n seal. At 1.25/square foot its worth a look. It is an aluminum backed butyl based product. I have used it on my footwells and seat box and floors with good results. It sticks great (even in the cold up here). At 6 inches wide its more work to cover large areas.
Based on a description of it with dynamat and BQ this stuff is comparable at a fraction of the cost. You can buy it at Lowes
I'll admit that back in the day, I've used home improvement products on cars and truck (mostly as a early 20-something when money was tight and my cars were shit).
However, this is a "gateway drug"! Next thing you know, you'll be using bathroom caulking to seal rust holes in your bulkhead and then you'll hit rock bottom and your door hinges will say "Schlage" on them!
In all seriousness, that stuff is a fraction of the cost because it's not engineered for that task. It could be flammable and most likely isn't designed for vibration and adhesion in those conditions.
I know when you buy hardware the basic rule is (in descending order of quality):
1) aviation grade;
2) marine grade;
3) automotive grade;
4) home improvement
Do yourself a favor and if you're not going to use proper components at least go UP a grade and find something used in the marine application, like the stuff used in the generator compartment or something.
Don't mean to scold or sound harsh, but who's gonna want a truck that has ice&water shield applied under the bonnet. It's a huge red flag to me, don't do it!
Old October 16th, 2014, 10:18 PM
akrockhound
Jack
1988 RHD 110
Lowes
try this one
http://www.lowes.com/pd_154017-81326...ductId=1018733
or type this into your browser
'01 Disco II
'95 RRC LWB
Old October 16th, 2014, 10:31 PM
jabber
m j
110
I've used both peel-n-seal and Dynamat... They both do the same thing, in the end. They're about the same thickness. You'd have to have super human hearing or be a machine to tell the difference.
I'd recommend peel-n-seal, as does my pocket-book.
Old October 16th, 2014, 11:26 PM
akrockhound
Jack
1988 RHD 110
thanks Jabber
Good to know - good for everyone to know
'01 Disco II
'95 RRC LWB
hood
Underhood winch controller box installs Uncle Douglas Defender Technical Discussions 19 October 2nd, 2013 11:07 AM
wrapping exhaust manifold to reduce underhood temperatures. cdb Defender Technical Discussions 16 February 15th, 2012 12:24 AM
underhood cleaning rustydefender Defender Technical Discussions 11 July 9th, 2006 04:13 AM
Underhood illumination Trevor Tarr Defender Technical Discussions 2 June 30th, 2005 01:28 AM
Replace tranny hump insulation??? JRowe Defender Technical Discussions 8 October 16th, 2003 10:35 PM
