Hi guys,
My most recent trip through the mud has left my engine bay filthy. Hof should I go about cleaning it without getting the ecu or other fragile electronics wet. I fell like I'm asking a dumb question but my ecu has gotten wet before which disabled my truck for the day.
Thanks fo the help
I know a guy once who used a pressure washer under the hood of his Wrangler..... sure was expensive in replaced components, so I wouldn't suggest that.
One thing I have done that works somewhat well is use a stiff nylon brush, something like a 3" wide paintbrush should be fine, and gently brush everything out. If the mud is really caked on and dried, it can be tough to get off without water. Sometimes using the brush and a bucket of water to dip it into will help, you just need to avoid the electonic components.
When I cleaned the engine I used an engine cleaner trigger spray on carefully. I wrapped all electrical components in plastic. Waited a while then used a warm hose with fine spray very carefully along with a soft brush.
Jimmy, his is a '97 so it has a lot more electronics under the hood that are vulnerable. On the 1994/95 trucks you really only have to worry about the distributor.
I have pressure washed mine several times. Now, I realize that it will eventually flake off on it's own and really don't bother with it. Maybe once a year....
I've pressure washed the motor and the the underneath - repeatedly - all 4 Range Rovers I've owned (including a current 1999 RR), and the 3 Defenders and never had a problem.
You know what's bad about pressure wash, it forced water where it's
not suppose to go, so even if you have a non-ecu or egr diesel engine,
i don't think pressure wash is the best think to do.
Buy a liquid degreaser, apply with a sprayer (like a water sprayer for plants),
wait a few minutes, then rinse it with gentle hose spray, and if you can
get your hand on one air compressor, blow some air to dry engine well.
In very dirty spots, you can use a paint brush with degreaser.
At the end of operation you can spray some WD40 on moving parts
like compressor pulley and also on rubber hoses (remember WD means
Water Displace).
Related Threads
Defender Source Forum
1M posts
24K members
Since 2003
