Undercoating and other newbie questions. - Defender Source
Old December 23rd, 2009, 09:42 PM
merlin8ty's Avatar
merlin8ty
Cliff Weinstein
1997 D-90 AA Yellow
Guys thanks for all the help on the "Simple Repairs" thread. Ended up taking the truck to Ricardo at the Foreign Car Center in queens. Real good guys but after getting the bill i need to make it a priority to get more involved with the NYC guys and start doing my own work with their help.
Two Questions:
Considering i will be traveling to vermont nearly every weekend for snowboard season...are there any suggestions for undercoating? There was another thread about this but didn't seem resolved. Can i do it myself? cost of undercoating? How time intensive is it?
The heat: I have a 97 with A/C. This might be totally normal but just curious. The levers on the left of the steering wheel are very difficult to move up or down. I feel like im about to snap them. One controls the "temperature" and the other changes direction, from all up top above the dash to some up top and some below by your feet. Does anyone else struggle moving the controls and/or breaking them? and should the heat blow out of the vents where my A/C blows out?
I'm looking forward to the next NY/NJ/CT meetup, I need to become more involved in this hobby!
Thanks.
Old December 23rd, 2009, 09:46 PM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
How do people feel about Ziebart?
I know it sounds dealer-cheezy but the FJ Toyota guys swear by it and spray it into all the rockers and door cavities and frame.
Old December 23rd, 2009, 09:49 PM
mjekogian's Avatar
mjekogian
Michael Jekogian
1997/ Defender ST
heat (what there is of it) will come out between your feet. My suggestion is heated seats you can put them in yourself for 100 , heated blanket or just man up and deal with it. I put heated seats in when I left CA.
Old December 23rd, 2009, 10:02 PM
merlin8ty's Avatar
merlin8ty
Cliff Weinstein
1997 D-90 AA Yellow
The temp is fine, i was just curious, i thought it was odd that it didnt blow out the vents.
It was 20 degrees today in New York and it wasnt cold at all. I actually had the window open on the drive back listening to the exhaust, they replaced some gaskets, sounds great now.
Old December 24th, 2009, 12:43 AM
Grover's Avatar
Grover
waxoyl...
http://www.robisonservice.com/servicedep/waxoyl.asp
or RN and apply yourself...
Cheers...
Old December 24th, 2009, 08:31 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
There is a guy in Manchester that does Waxoyl too and cheaper, Bob Bushee.
Old December 24th, 2009, 09:02 AM
Just have the truck regularly rinsed off underneath and save the undercoat for a summer project. Before undercoating you need to be pretty sure the truck is in good condition ... undercoating can conceal problems.
My heater controls are pretty stiff too, the cables are probably a bit dry and need some lube. I would imagine that it's possible to remove the inner cable and lube it all up nicely without too much hassle.
Old December 24th, 2009, 11:04 AM
One vote here for no undercoating. Lots of people swear that it helps reduce corrosion, but I think that's just hype from the people who make the stuff. I would never put Waxoyl or anything else on the underside. This is especially pertinent for those who use their trucks off road.
Old December 24th, 2009, 11:10 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
I'd have to disagree 100% Bill. Waxoyl is unlike any type of rubber coating that could hold in moisture. A properly prepped and done job of waxoyl absolutely preserves a frame.
Old December 24th, 2009, 11:14 AM
Waxoyl works. Not a matter of opinion, all you have to do is compare vehicles that haven't had it to those that have. It isn't like some of the other coatings that end up trapping moisture.
landrovered's Avatar
landrovered
S. Smith
72 Series III 109 Diesel
Do not use asphalt or rubber based undercoating EVER. I spent four days with a torch and a putty knife scraping that crap off of my series III chassis and it does not inhibit rust. It just hides it. Waxoyl is better but the best is cleaned properly prepared metal with POR or chassis saver paint.
Old December 24th, 2009, 12:02 PM
Gunmaker's Avatar
Gunmaker
Michael Ullman
1995 D90 SW #270
I have no experience with Waxoyl but I do with undercoating. The PO had it done on my truck. It is now costing me quite a bit of coin to replace the frame and several parts that were rusted. It trapped moisture and the frame just rotted. Funny part is, maybe more sad than anything, is there were spots where the coating had worn off quickly, those spots looked brand new, from the shop floor. But places where it had just cracked and peeled a little, it trapped moisture and salt from the roads. Some of the holes were big enough to put my fist in. You can see the damage on the frame swap thread the SafariRover started under major projects.
Old December 24th, 2009, 12:11 PM
says the guy who lives in georgia...
Old December 24th, 2009, 03:28 PM
The controls can be lubed and should move freely if lubricated. Pretty easy to get into the dash and hit them with wd40.
It only blows out 2 vents below the dash (on a '94 these came out holes in the AC facia), and up onto the windoshield
hth
charles
Old December 24th, 2009, 03:40 PM
On the 97's the heat either comes out in the foot wells or the defroster vents. The heat and AC are two completely separate systems.
Old December 24th, 2009, 04:48 PM
KKilo23's Avatar
KKilo23
Kenny
Waxoyl... Dawson in CT ...Classic's 4x4...
The treatment includes power washing the entire underside, and engine compartment. Applying hardwax-(black) to the entire underside, as well as the entire frame and crossmembers etc. Then the vehicle gets the waxoyl-(clear), applied to all of the flooring, engine compartment, inside of the fenders, doors, quarter panels, and frame etc.
They pressure wash the 1st night and dry the vehicle. Then wrap the vehicle up with protective material, and apply the hardwax. Next evening, when they apply the waxoyl.
After vehicle is washed, and checked for overspray.
You can then pick up the vehicle on the 3rd day.
The cost was $850.00
The price might have gone up... but that is what it was a couple of months ago...
