Undercoating - Page 2 - Defender Source
Old October 13th, 2009, 12:13 PM
Done.
Let's get it all off amazon as it will probably be cheaper.
Ron
edit:
Make sure the mineral spirits I listed are not the safe kind. We probably want the nasty stuff.
Shit. Just call me when you get a chance and I sort this all out tonight. Home depot is next to the liquor store/tobacco outlet so I will stop in on the way home.
Old October 15th, 2009, 12:00 PM
RibTickler's Avatar
RibTickler
David Shetron
None - But Looking
Since we are on the subject of cheaper methods of undercoating, has anyone tried "Finnigans Waxoyl"? It seems to be what the MGB folks are using. It's also much cheaper than the Rovers North "Waxoyl".
Dave
Old September 28th, 2010, 12:37 PM
bamanuke's Avatar
bamanuke
mike hall
'97 alpine white sw # 0127
Ron,
Did you ever get this mixedup/applied? My truck was waxoyled some time in it's past and needs re-coating. i was looking into just using the spray cans from RN. thanks,
Mikel
Old September 28th, 2010, 02:12 PM
Mixed up, but not applied.
Old September 30th, 2010, 09:01 AM
Gunmaker's Avatar
Gunmaker
Michael Ullman
1995 D90 SW #270
Thank goodness this truck had undercoating other wise it might of rusted. You can even see the coating on the second picture. At least it did not trap any moisture and rust from the inside out.
ID:	31736   Click image for larger version
My Rover doesn’t leak oil, she is marking her territory.
Old September 30th, 2010, 03:36 PM
Your truck appears to have rusted inside out (as most do). waxoyl has two types, the homemade stuff mimics the stuff you spray inside cavities to prevent what happened to your truck.
Old September 30th, 2010, 10:53 PM
DieselDef
Brad Ingalls
1985 Defender
Is anybody familiar with Dinitrol? The review I just read comparing treatments advised that Dinitrol is a bit better. Not sure where to get it here in the states though. If I'm going to be spraying that stuff from underneath I want to do it the best way I can the first time.
Old October 1st, 2010, 07:33 AM
Gunmaker's Avatar
Gunmaker
Michael Ullman
1995 D90 SW #270
Yes it did rust from the inside out in spots. But it also rusted under the undercoating. Infact the spots where the undercoating had worn off looked like they had been out of the show room for only a year. Almost brand new.
Old October 1st, 2010, 07:46 AM
Chris Velardi's Avatar
Chris Velardi
Chris Velardi
1975 101FC
Eastwood now has a new internal chassis (frame) coating product called"Internal Frame coat " Stops rust from the inside by penetrating and converting and encapsulating any possible internal frame chassis rust uses a zinc Phosphate product # 12515Z www.eastwood.com I bout a 2 pack of aerosol cans to do the a and b posts and sills of my MGA
Chris "V"
Old October 2nd, 2010, 08:54 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Chris, I bought some as well but haven't tried it yet. have you?
Old October 2nd, 2010, 09:57 AM
Chris Velardi
Chris Velardi
1975 101FC
Not yet, just bought it because they put it on sale
Chris "V"
97 SW getting a few upgrades crown14 Truck Build-up's & Restores 269 February 7th, 2015 01:56 PM
Undercoating and other newbie questions. merlin8ty Defender Technical Discussions 15 December 24th, 2009 04:48 PM
Rear Load Matt - bjf Defender Technical Discussions 11 November 17th, 2008 01:41 PM
Undercoating jracenstein Defender Technical Discussions 4 February 5th, 2005 10:11 AM
Undercoating PT94D90 Defender Technical Discussions 9 October 4th, 2004 03:39 PM
