Under-Dash Leaks? - Defender Source
Old April 29th, 2012, 07:46 AM
Philster2
Phillip Krall
1994 D90
Under-Dash Leaks?
i've been having mysterious starting problems with my '94. The latest place that the search for an answer has led is to the fuse box/ relays. Things are badly corroded and there is water. Any idea of the likely source of a leak? Any suggestions would be very appreciated.
Phil
Old April 29th, 2012, 10:09 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Dash vents would be the first suspect.
Old April 29th, 2012, 02:57 PM
Bingo. Just replaced mine and it appeared to be the issue. However, don't count on the adhesive backing on the new vent seals...I did and it failed within days. I had to remove everything again and put it back on with 3M weatherstrip adhesive.
Old April 29th, 2012, 03:36 PM
berti1554
Robert Klima
84/110
Use the Series vent seals instead the later Defender ones. The older style seals are of a different rubber/foam material which seals better. And as Jason already said use some good adhesive...
Robert
Old April 29th, 2012, 03:42 PM
Robert
Just keep in mind the older ones seal against the bulkhead (rather than the vents themselves). I opted for the same vent style just so I didn't have to see them on the bulkhead.
Old April 29th, 2012, 07:39 PM
flananuts
Matthew
LRC Customs #003 D110 Soft Top
I swapped mine out to the series mounted on the bulkhead. They are legit. You may want to pull your dash out because there is likely rust along the seam at the bulkhead and the footwells. Mine definitely did due to years of leaks prior to taking ownership. A little extra effort will go along way.
------ Follow up post added April 29th, 2012 07:40 PM ------
It could also be a plugged drain in your heater fan intake sucking in moisture and then working down the bulkhead into your fuse panel. I would till bet on the vents though.
Old April 29th, 2012, 09:11 PM
Philster2
Phillip Krall
1994 D90
Thanks for your input. This definately leaves me with a couple places to look.
Old April 30th, 2012, 06:03 AM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
Did you pull the vents off to replace the seal or did you cut the seal in order to get it around the lever arm?
1997 P38 4.6
1998 P38 4.0
2011 LR4
Old April 30th, 2012, 09:51 AM
I did pull them...but it's because I had to repair one of the vent arms anyhow, plus I had the inside dash out too so it seemed like the time to do it.
Old April 30th, 2012, 09:55 AM
flananuts
Matthew
If you knock the pins out, it's very easy to get a small ratchet on the bolt that connects the arms to the vent. The other bonus is it's much easier to clean off all the old residue etc. I ended having to use laquer thinner, a rag, and a scraper to get it clean, but it did a fantastic job.
dash
Dash Rotted Out, Had to Fix It JimC Misc. Chit-Chat 7 February 6th, 2009 03:20 PM
New Defender Dash parts TDI Guy For Sale - Parts 1 April 3rd, 2005 10:58 AM
Leaks - D90 Wagon Kimos Defender Technical Discussions 22 January 3rd, 2005 12:28 PM
Dash install of radio paulb Defender Technical Discussions 3 December 17th, 2004 05:42 PM
1997 Dash panel - what's there? ronward Defender Technical Discussions 6 April 26th, 2004 05:47 PM
