Under bonnet fuse box diagram - Defender Source
Old August 10th, 2015, 09:42 PM
My under bonnet fuse box on my 1994 NAS D90 does not have a lid, and I'd like to verify the fuse functions since it's blowing the second fuse from the top.
The pdf of a NAS V8i Defender manual I have says
30A PI System
30A Lighting System
60A Ignition System
60A Aux aircon system
What's bothering me is when this fuse is blown, the only things that work are the lights, so how could the lighting system fuse be blowing! I take it back, the running lights come one, and I have to push/pull the turn signal stalk to get the high beams to come on. But no turn signals, no dash lights, no sign of life from the ignition.
I have no idea what the "PI System" is
I am not sure if it's coincidence, but right before this fuse blew, I lost the tach and the battery light came on (so assume my alternator died), and I drove for about 15 minutes before the fuse went.
tia
charles
Originally Posted by pendy
I'm here for the D's
Old August 22nd, 2015, 05:47 PM
For the archives, the top (bottom when looking at the label) 30A fuse if the Fuel Ignition System.
Also, despite being the Lighting system, this fuse is undeniably involved in the ignition process and your truck will not run when it's blown. In my case it turned out to be a bad coil which was causing this to blow. I can only assume my alternator killed it.
Fuse Box: Glass fuse --> Spade Fuse gonzanc Defender Technical Discussions 20 October 27th, 2016 11:54 PM
Looking for a ROW fuse box diagram BEIS Misc. Chit-Chat 11 July 12th, 2013 03:36 PM
Wanted - D90/110 Under Bonnet Fuse Box ipgregory Wanted 3 June 30th, 2012 06:44 PM
fuse box diagram and amp values? Gkase Defender Technical Discussions 0 April 7th, 2010 02:22 PM
Need 1997 D90 fuse box cover- under bonnet Viton Wanted 0 January 4th, 2009 02:49 PM
