uk 13pin trailer loom - Defender Source
Old August 26th, 2016, 11:27 AM
avergo
graham
defender puma
Problem
Trailer loom on defender puma
Loom socket on the car has got power too brake light wire
plug that goes into car loom too rear socket this wire is good but when I plug the 2 together I have no power to brake lights at the rear socket
Its a 13 pin rear socket I'm fitting every thing else is working just no brake lights
Can anyone help Please
Old August 26th, 2016, 12:25 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
You'll need to describe what and where each pin goes to get any real help.
Some trailers combine the signals and brake lights onto the same bulb filament.
If this is the case you'll need a converter that cuts out the brake light to the specific side when the signal light is flashing.
RDavisinVA
Old August 26th, 2016, 12:34 PM
avergo
graham
defender puma
IM in the uk
I think our wiring for lights is different than the usa
ECU relocation loom maleger Defender Technical Discussions 8 May 15th, 2015 06:53 AM
Td5 wiring loom with 300tdi anfonee1 Defender Technical Discussions 5 September 1st, 2013 11:07 AM
Kind of new take off 200 TDI Main Loom SafariHP The Vendors Loft 1 May 28th, 2013 02:31 PM
LHD TD5 bulkhead wire loom rayfi For Sale - Parts 2 November 7th, 2009 12:59 PM
ARB M002 Heavy Duty Wiring Loom Troys Defender Technical Discussions 1 December 15th, 2006 02:55 PM
