Ujoint replacement - Defender Source
Old October 8th, 2007, 08:24 PM
Andrew Vick
Andrew Vick
95 D90
Ujoint replacement
I've got a bad ujoint at the diff end, and the bolts on the brake drum end spin freely. I'm assuming I'll have to cut the nuts off to get that end undone, but if anyone has other advice, I'm open.
Should I replace the ujoints at both ends, or just the one that is bad? They were both done 2 years ago, but I think crappy ujoints were used.
Thanks!
Old October 9th, 2007, 08:17 AM
Definitely do both joints.
Are you sure they spin freely? Mine feel loose, but hold fine when wrenching on the nut. I assume you will have to cut off those nuts, remove the drum and brake assembly, and then the flange to get new studs on it. But you do want to address that. Ouch.
charles
Old October 9th, 2007, 08:29 AM
Andrew Vick
Andrew Vick
95 D90
One of the nuts on the drum side came off fine, but it's a different nut. It has a flanged shoulder and isn't a locking nut. The others just spin and spin, so one is now cut off with 2 more to go. Once that's off, I'm wondering how I'll secure the new bolts from the back side. Any help there would be really appreciated.
Old October 9th, 2007, 08:53 AM
Once you get the brake drum off you should be able to remove one of those cut off bolts and determine how they fasten to the flange. Hopefully someone else knows more about this, sorry.
Old October 10th, 2007, 07:14 AM
Andrew Vick
Andrew Vick
95 D90
Update. The don't fasten to the flange. They are held in place by the head of the bolt sitting flush against the shoulder of the flange, just like the diff end of the front shaft. Don't yet know why those heads seem too small, but they'll get replaced.
What size nut holds the flange on? Thing is huge!
Old October 10th, 2007, 08:06 AM
Yeah that makes sense. Good news!
Old October 10th, 2007, 09:51 AM
Andrew Vick
Andrew Vick
95 D90
Sounds like 30mm. Can anyone confirm?
Old October 14th, 2007, 04:37 PM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
I think my diff side u joint is bad as well. It makes an awful grinding sound when spinning. I thought I had a rock in the muffler by the sound of it. Do you guys think it could be done?
Ok joking aside, where should I get my new u joints? I plan to replace all 4 of them.
Old October 14th, 2007, 09:20 PM
All the regular places. George at RDS, Rovers North, etc.
Old October 14th, 2007, 09:36 PM
rmuller
Ryan
1966 S2a 88" | 2006 LR3
diff flange? 32mm
Ryan
Current:
1966 Series IIa "Olive"
2001 Discovery II
2006 LR3 HSE7
Old October 14th, 2007, 09:56 PM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
yeah, George has the best prices as usual. I was wondering if anyone used ant aftermarket u joints that may be a little better.
Old October 14th, 2007, 10:14 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
www.floridapowertrain.com
- Charles Eames
Old October 14th, 2007, 10:38 PM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
Originally Posted by JFD
Umh, what about it? I can't find any u joints on the site.
Old October 14th, 2007, 10:58 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Send them a mail. They have Dana Spicer that will fit your truck.
- Charles Eames
Old October 14th, 2007, 11:06 PM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
Thanks.
I don't kow about the Dana spicer. Is it better than OEM?
Old October 14th, 2007, 11:12 PM
Baldewin's Avatar
Baldewin
Chris Baldewin
Bastard 90
Diff flange is 30mm, four bolts should be 10mm x 1.25 pitch and lenth is 30 or 35mm. Head size of 10mm bolts should be 14mm.
CB
Old October 15th, 2007, 08:22 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Thanks.
According to people on Tom Wood's website, yes.
According to my experience, can't tell because I have
the parts but didn't do the job yet, parts looks pretty all right,
greasing nipple is on the side.
http://www2.dana.com/expert/wc.dll?h...rts~locatea_ld
- Charles Eames
Old October 16th, 2007, 12:21 AM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
Well I just pulled mine awaiting the replacement u joint from George at RDS. It was pretty darn easy. So why pay $250 for a u joint when they are this easy to replace? I guess its just personal preference.
now I need to work on that pinion angle. What is the correct rear pinion angle again?
Old October 16th, 2007, 12:32 AM
Pressing the u-joint out/in can be a pain without a press, but no u-joint is worth $250
I am not sure, but I believe you want the pinion to be parallel to the output shaft of the transfer case.
hth
charles
Old October 16th, 2007, 09:21 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
250 ?
I pay 40 for each Dana...
- Charles Eames
ac
Clutch replacement difficulty? Trigger Defender Technical Discussions 3 July 25th, 2005 03:18 PM
Relay replacement help cgalpin Defender Technical Discussions 21 April 18th, 2005 07:42 AM
rancho bushing replacement? jorge Defender Technical Discussions 6 April 7th, 2005 03:36 PM
Front Vent Seal Replacement Campbell Defender Technical Discussions 16 October 28th, 2004 09:11 PM
Replacement Headlamps tuko Defender Technical Discussions 4 November 18th, 2003 09:51 PM
