U-joints for early defender (1984)? - Defender Source
Old April 23rd, 2012, 02:59 PM
Hey folks. I think it's time for me to do my U joints (front and rear) since they have a lot of play. I want to get this done before the next wheeling trip up to Rausch.
http://www.defendersource.com/forum/...ghlight=joints
Tom's informative post says that early Defenders use the Advance auto 1-0153 U-J
then:
"I picked up a PDQ 1-0154 u-joint from Advance Auto today just to check them out. They can be used in lieu of 1-0153 (Spicer 5-153x). The difference is the zerk is in the end cap on the 1-0154."
Would the 1-0154's work for both the front and rear driveshafts on an early D90 (1984)?
Old April 23rd, 2012, 07:21 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
The surest way to know is to remove the old ones and measure. The factory parts manual for mine isn't even correct.
Outside Cup Diameter and the over all length (with cups on) of 2 apposing cups, are the measurements you need.
Old April 23rd, 2012, 08:38 PM
Yeah there seem to be various sizes. But do yourself a favor and find ones without a zerk in the end cap. They WILL get broken off when you wheel.
Originally Posted by pendy
I'm here for the D's
Old April 23rd, 2012, 08:41 PM
ooh, thanks for the suggestion guys.
Old April 23rd, 2012, 08:55 PM
I went the NAPA route last time. They have two grades of the same part for the application. The made in the USA part was a pita to press in compared to the cheaper made in Japan version. For me the Japanese version pressed in much easier and the seals appeared to be of higher quality. I have the auto zone ones in my 130 front shaft- 40k and counting.
Old April 23rd, 2012, 09:07 PM
Jpayne's Avatar
Jpayne
Jeff Payne
'83 110 3 Door
I used the 1-0153 in my front driveshaft on an 83. It has the zerk recessed in the middle of the joint. Not sure what to use in the rear since I replaced my rear driveshaft.
Old April 24th, 2012, 03:39 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Cap diameter is the same between the 1310 and the 1300 series, just the length is different, but yeah, the best way would be to measure the length. They are different enough you should be able to do it with a ruler, if you can't afford the down time.
I've never broken a zerk on the end cap, but then I always replace them with flush fittings.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old May 9th, 2012, 03:50 PM
To close the loop on this thread:
I screwed up and bought both the wrong kind of Universal Joint and too few of them.
I bought two 1310 series u-joints at Advance, and I found out that I needed four 1300 series.
Charles saved the day by having two 1300 series u-joints on hand. Thanks again Charles
So I (well, more like Charles) replaced the u-joints in the rear. His vise was also destroyed in the process of trying to press out the caps. What worked out best in the end was the "pound out the caps with a hammer and a socket" method.
It also turned out that most of the play I was experiencing wasn't actually in the driveshaft but is somewhere in the axle. Oh well...in for a dime, in for a dollar-ish.
Thanks again to all for the advice.
94 NAS Defender 90-P.O.E.(Port of Entry) 1 of 65 made! on EBAY SeanD-90 Misc. Chit-Chat 29 May 27th, 2017 07:14 AM
1984 Defender 110 Station Wagon 300tdi Shearpin For Sale - Vehicles 7 April 30th, 2012 02:52 PM
For Sale: 1984 Land Rover Defender 110 SW RHD (asking $35,000 US obo) 97XD For Sale - Vehicles 2 October 6th, 2011 11:23 AM
1984 Defender 110 for sale Shawn For Sale - Vehicles 9 June 29th, 2011 02:24 AM
