U-joint question - Defender Source
Old March 16th, 2014, 12:59 PM
Spenc1tj's Avatar
Spenc1tj
TJ Spencer
1997 NAS Defender
U-joint question
So in the process of greasing my u-joints yesterday I snapped the grease sert off the rear on the front shaft. Tried using tap/bolt remover, no luck. Looks like I'm just going to get 2 new joints and replace them. They could be oem and will most likely be heavily seized. As I have no garage to work in, vise, press, etc. it will take longer than typically necessary. I do not have time to get it done during the week as I work everyday and refuse to take my defender to any shop unless absolutely necessary, not getting a u-joint done at a shop, that's absurd.
My question is; do you think it will be ok through the week just to get to work and back? (30-40 miles/day) until u have time to tinker with it in the driveway? Hopefully it's warmer then too! Thanks!!
Old March 16th, 2014, 01:19 PM
Originally Posted by Spenc1tj View Post
So in the process of greasing my u-joints yesterday I snapped the grease sert off the rear on the front shaft. Tried using tap/bolt remover, no luck. Looks like I'm just going to get 2 new joints and replace them. They could be oem and will most likely be heavily seized. As I have no garage to work in, vise, press, etc. it will take longer than typically necessary. I do not have time to get it done during the week as I work everyday and refuse to take my defender to any shop unless absolutely necessary, not getting a u-joint done at a shop, that's absurd. My question is; do you think it will be ok through the week just to get to work and back? (30-40 miles/day) until u have time to tinker with it in the driveway? Hopefully it's warmer then too! Thanks!!
Yes probably fine and you can drive in 2wd with the diff locked once you pull the shaft if it has issues. If it is the front, it is the same as a disco I so you can just get a used one for cheap and have a spare.
Old March 16th, 2014, 01:23 PM
CMSgt Bo's Avatar
CMSgt Bo
Bo
1985 One Ten
You're definitely going to lose your grease over time. If your bearings are good the loss of grease over the course of the week shouldn't be that big of a problem.
Proud member of the YCHJCYA2PDTHFH club.
My mechanic told me, "I couldn't repair your brakes, so I made your horn louder."
Old March 16th, 2014, 01:24 PM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Pack your newly found hole with JB weld and drive it until it becomes a problem.
Old March 16th, 2014, 01:28 PM
Spenc1tj's Avatar
Spenc1tj
TJ Spencer
1997 NAS Defender
I like the JB idea. I also thought about a small self tapping screw....?
Old March 16th, 2014, 01:34 PM
CMSgt Bo's Avatar
CMSgt Bo
Bo
1985 One Ten
The screw is a great idea. The JB weld may not set well on a greasy area.
Old March 16th, 2014, 01:35 PM
Did you try drilling it out? They are soft metal in my experience.
Old March 16th, 2014, 01:53 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Plug the hole and get some new U-joints put in next weekend. Even if they go out on you (roller bearings stop rolling and turn to powder) the likelihood of catastrophic failure in the next 200miles is minimal.
Old March 16th, 2014, 02:13 PM
Spenc1tj's Avatar
Spenc1tj
TJ Spencer
1997 NAS Defender
I don't have my drill with me here in STL. I bought a nice tap/bolt remover with a nice bit and it gripped it but that thing would not budge. I figured it'd be easy but no. No biggie, I think once it warms up tomorrow I'll put a small self tapper in it and replace both joints on the front shaft this weekend (old school/trail style with a hammer, socket, vice grips and a piece of split log! Lol) thanks for the input fellas!
Old March 16th, 2014, 02:17 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
buy a 6" C-clamp for $15 to make the installation go easy
Old March 16th, 2014, 02:21 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Yep I use a C clamp and a socket to press them in and out.
Jimmy Buffett
Old March 16th, 2014, 02:39 PM
Spenc1tj's Avatar
Spenc1tj
TJ Spencer
1997 NAS Defender
I do have a 6" c-clamp. Good idea. Thanks.
Old March 19th, 2014, 10:21 AM
michael67's Avatar
michael67
Michael White
110 Tdi
If the C clamp doesn't work, you can always just take just the drive shaft in to a machine shop to have new U-joints pressed in.
Rear propshaft with CV joint question anfonee1 Defender Technical Discussions 2 October 31st, 2013 12:50 AM
Rear Wishbone Ball Joint Assembly, Tie Rod End & Drop Arm Ball Joint Rebuild Kit BMGmotors Defender Technical Discussions 18 June 27th, 2011 01:59 PM
heim joint question erik d Defender Technical Discussions 1 November 7th, 2004 06:50 PM
U Joint question Milo Defender Technical Discussions 4 August 24th, 2004 03:45 PM
