tyre sizes - Defender Source
Old December 13th, 2012, 07:43 AM
defenderizl's Avatar
defenderizl
leon bonhomme
defender 110
tyre sizes
I,m driving 16" modulars now. But can get my hands on a very nice set of mach 5,s, only disadvantage is that they are 15".
I don,t want to change my ride to much. I,m driving on 235/75/16.
Whats comparable to that
Leon
Old December 13th, 2012, 07:50 AM
The Dro
Dro
1988 Ninety
I don't quite understand your question.
Anywhoo... Here is a nice tool to find a tire size and be able to compare them.
http://www.1010tires.com/tiresizecalculator.asp
------ Follow up post added December 13th, 2012 07:51 AM ------
Also try http://www.defendersource.com/tire/index.html
Old December 13th, 2012, 08:08 AM
defenderizl
leon bonhomme
defender 110
Thanks was all i need
Old December 13th, 2012, 08:17 AM
The Dro
Dro
1988 Ninety
Glad it helped.
Old December 13th, 2012, 10:04 AM
That is not a disadvantage. 15" wheels give you a much wider range of tires to choose from and prices are cheaper.
Old December 13th, 2012, 12:39 PM
defenderizl
leon bonhomme
defender 110
I meant that i can,t use the tyres I've got now. The springs will be +2 inch also so normally I should be able to fit bigger tyres. I don't have power steering so much wider isn't much of an option is it? I like the look on the one-tons, (9x16)??
The thing is I don't have much experience with that. Do I have to change the gearing ratio. Does it affect the axle travel, should I change the bump stops.
Please share your wisdom.
Old December 13th, 2012, 12:51 PM
defenderizl
leon bonhomme
defender 110
I don't want to confuse you to much.
What is available for 15"rims and looks and drives still ok
Tires sizes per lift ratio ini88 Defender Technical Discussions 9 December 22nd, 2005 01:02 AM
Tire Sizes NashvilleRedD90 Defender Technical Discussions 2 February 8th, 2005 07:34 PM
Tire Sizes Kimos Defender Technical Discussions 12 December 1st, 2004 11:53 PM
Rear Spare Tyre Carrier Noises??? adibitar Defender Technical Discussions 7 May 23rd, 2004 07:49 PM
photo sizes - how to reduce paulb Support & Suggestions 2 November 26th, 2003 05:12 PM
