Two "S" Type Spade Connectors on My Starter Soldenoid? - Defender Source
Old February 26th, 2016, 11:54 AM
Bayonet16's Avatar
Bayonet16
1984/110
I have two "S" terminals (spade type) on my starter solenoid. This is in addition to the "B" and "M" terminals (post type). I've never seen two spades on a starter before. Can anyone tell me what the second one is used for?
It's a Lucas and I believe it was originally on a 2.5L NAD. Found it in a box o' parts I got with the engine and it bench-tested better than the one on the engine, so I R&R'd it.
Old February 26th, 2016, 12:05 PM
couldn't say on your truck but early 3.5 v8's had a weird system where the ignition worked on one voltage for a hotter spark on start and then dropped the voltage so points didn't burn up as quickly. The start voltage was pulled from the starter signal wire and bypassed the ballast resistor over by the coil. As soon as you released the starter
position on the ignition switch, the ballast bypass was closed.
start, starter
Fuse Box: Glass fuse --> Spade Fuse gonzanc Defender Technical Discussions 20 October 27th, 2016 11:54 PM
Glass to spade fuse questions burlsube Defender Technical Discussions 19 June 19th, 2016 09:46 PM
3 spade 110 diesel fuel sender with only two wires flananuts Defender Technical Discussions 10 February 4th, 2014 08:15 AM
What type of electrical connectors are these? josh-man Defender Technical Discussions 12 June 24th, 2013 03:34 AM
Michelin "X" 7.50 R 16 4X4 "N" Tube Type COSteve For Sale - Parts 5 July 23rd, 2008 03:16 PM
