TVR Running! - Defender Source
Old June 30th, 2004, 07:06 PM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
TVR Running!
Fired up the TVR for a few minutes for the first time today! Very exciting moment! Very deep, throaty, resonant, angry. Sounds like the real monster I suspected it would be! We fired her with the 110s 14CU ECU. Later this week we'll put the RPI chip & Disco ECU on and see how that settles out some of the roughness (along with timing and base idle adjustments.) More news to come.
Looking for suggestions:
1. The fan shroud for the 110 doesn't fit over the new fan. Oddly enough, the 5.0 fan is not in the same position as the 110 fan -- its about 4 inches to the driver's side (different water pump). We're probably just going to wind up making something, but just fishing for ideas and suggestions now...
2. The new plenum is for a '98 4.6 RR. The diameter of the plenum intake is larger than the 3.9 hose. Any ideas where I could shop for some generic intake hose that's larger diameter and of sufficient length? Need about 3 feet.
DW
Old June 30th, 2004, 07:47 PM
electric cooling fans maybe?
Old June 30th, 2004, 08:10 PM
Doug's Avatar
Doug
Doug Walker
Thought of that! It's on the list.
Old June 30th, 2004, 10:24 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Doug, plenum hose! junk yard! Try to find them from an 90's ford pu. 7.5 ltr You want the angles. Then use some alum pipe for the straights. I did this for another truck I had. I was fortunate to have the intake hose from my old f350. It not as clean as the stocker but it will work. I also had this idea during this process. Find a industrial electrician they should be able to bend large id od conduit. The other option is industrial food hanlding equipment maufacturer. that was a mouthful. They work with large stanless pipe & should be able to bend vary easly. Hope this helps!!!
Old July 1st, 2004, 12:50 AM
Doug's Avatar
Doug
Doug Walker
Humm, I like the Ford bends, with the aluminum pipe. In fact, could go with a junk RR 4.6 hose and aluminum straights. Thanks, good idea....
Old July 2nd, 2004, 02:34 AM
but just fishing for ideas and suggestions now... (shroud)
Maybe it is like the 4.0 on 97 D90s?
Just something to look into, I know the 4.0 serp W/P is probably what is on there.
Ron
Old July 2nd, 2004, 10:35 AM
Doug's Avatar
Doug
Doug Walker
Thanks Ron. We figured out the shroud yesterday. Invert the 110 shroud (bottom on top, top on bottom) and it fits exactly! A little trimming and adding, should be fine! Sheesh. I measured a 95 RR, but the radiator was shorter and wider, so no go there. This should work fine.
Running Rich Please Help bstraw Defender Technical Discussions 23 October 26th, 2007 10:44 AM
2 Sets of Running Boards steved90 For Sale - Parts 10 March 2nd, 2006 02:28 PM
Dash, Running & Head light PROBLEM ! Weldon Defender Technical Discussions 5 November 9th, 2005 02:04 PM
It's Running! Mike Hippert Misc. Chit-Chat 26 June 2nd, 2005 08:04 AM
DS Running light? Eric Siepmann Defender Technical Discussions 1 June 27th, 2004 07:55 PM
