Turn Stalk - Defender Source
Old May 29th, 2010, 02:14 PM
tomaco1's Avatar
tomaco1
T.mac
83 110
Turn Stalk
The switch that controls the brights is no longer working, I assume I need a new one, but can it be fixed? even temporarily until the new one gets here.
Old May 29th, 2010, 07:17 PM
Yes, you can goob a bit of solder on it to make it work.
Old May 29th, 2010, 09:25 PM
mjekogian's Avatar
mjekogian
Michael Jekogian
1997/ Defender ST
The locking nut came loose on mine and stopped it from working. I would check that first. it's the nut that tightens it to the column
Old May 30th, 2010, 08:52 AM
Chris Velardi's Avatar
Chris Velardi
Chris Velardi
1975 101FC
The key is to raise the height of the contact (without melting the plastic around the switch any further ) electrical solder is the key
Chris "V"
Turn Signal Failure arbik Defender Technical Discussions 53 October 11th, 2010 10:51 PM
94 turn signal stalk CDeWan Wanted 3 January 6th, 2009 10:23 PM
Euro style front turn indicators boshea Defender Technical Discussions 12 September 22nd, 2005 07:56 AM
Turn signal--problem solved Davis Defender Technical Discussions 0 July 18th, 2004 08:13 PM
