Turn Signals (rears work, fronts don't) - Defender Source
Old September 2nd, 2006, 10:27 AM
cmcarp
Craig M. Carpenter
2000 Discovery
'94 D-90. All running lights work. Rears flash. Fronts do not. Getting fast flash from the flashing unit. Is there a ground I should be checking?
Thanks in advance for any tips.
Old September 5th, 2006, 02:54 PM
Sometimes banging on the front wing makes them work. Otherwise fallow the wires back and check all connections.
Old September 5th, 2006, 04:55 PM
cmcarp
Craig M. Carpenter
2000 Discovery
Thanks. Makes sense. It actually started happening after one of the lenses got cracked. It has a SG front bumper, so the bottom running lights on the front of the wings are now serving as the turn indicators. I will chase down the grounds and see if this is the source of the problem.
signal
Turn signals don't work cdb Defender Technical Discussions 4 April 30th, 2009 11:10 PM
turn signals and flashers not working draaronr Defender Technical Discussions 4 April 27th, 2008 10:19 PM
Relocating Turn Signals Doug_Paoletti Defender Technical Discussions 13 July 26th, 2005 11:49 AM
