Turn signals out - Defender Source
Old April 6th, 2014, 08:35 PM
Turn signals out
O basically they just stopped today, both left and right signals, all other lights work, high beams, etc on the same stalk. Hazards don't.
I replaced the relay about 6 months ago.
So what are the odds it is the relay, or the hazard switch?
Fuses are not blown either.
95' D90 - daily driver..
Old April 6th, 2014, 08:45 PM
Or the flasher.
Old April 6th, 2014, 08:47 PM
I'd put money on the fact that you just need to pull your hazard switch out slightly. This used to happen to mine periodically, until I took the switch apart and cleaned it all. Give it a try.
For what it's worth I'm working on a conversion kit to the Carling Hazard Switch for the NAS trucks.
Old April 6th, 2014, 10:07 PM
101stAirborne's Avatar
101stAirborne
Battle Ewing
1997 D90 LE 255/300
That's what started with my 94. Next to go out was the fuel pump. The cause was the computer(EMECU).
Old April 6th, 2014, 10:24 PM
How does the fuel computer have anything to do with the flasher relay? Serious question...
I'm going to pull the fuse box tomorrow and hopefully replace the relay with an auto parts bit if I can find one and go from there.
I do have a spare ECU but haven't ever tried it. I probably should anyway.
Old April 6th, 2014, 10:51 PM
On further review....
Blown hazard fuse, fixed now. I'll see if it repeats and go from there if needed.
Old April 6th, 2014, 11:08 PM
101stAirborne
Battle Ewing
1997 D90 LE 255/300
Fuck if I know!
Old April 6th, 2014, 11:30 PM
Gotcha...
turn signals and flashers not working draaronr Defender Technical Discussions 4 April 27th, 2008 10:19 PM
Relocating bumper turn signals to the upper light housing paulb Smaller Projects 1 March 17th, 2007 10:50 AM
Flasher Unit LED turn signals rustydefender Defender Technical Discussions 2 November 14th, 2006 09:28 PM
Turn Signals (rears work, fronts don't) cmcarp Defender Technical Discussions 2 September 5th, 2006 04:55 PM
Relocating Turn Signals Doug_Paoletti Defender Technical Discussions 13 July 26th, 2005 11:49 AM
