turn signals and flashers not working - Defender Source
Old April 25th, 2008, 08:40 PM
draaronr's Avatar
draaronr
Here
LR3
I did a search but didn't find exactly what I needed. Here it is hit the stick on the column to turn the turn signals on and nothing happens. Then hit the hazzard switch and nothing. Now hold down the hazzard switch and all 4 signals do the normal rate flash, as soon as you remove your finger the flashers stop.
Now it gets weird. I took out the seats and cleaned up the dash around the steering wheel and center console. (97 by the way) and started the truck up to move it and I thought what the hell I hit the stick and the blinkers on the drivers side came on, turn them on the passenger side and they came on, now the inside indicator wasn't lighting up but I could hear the rhythmic ticking of the blinker switch(or relays). So i turn them off, and hit the hazzard, holy shit it works and it the switch is lighting up but still not on the dash.
So I check the blinkers again, and son-of-a-bitch it's not working again, hit the hazzard and nothing.
What do I need to check, and what should I be looking for.
Old April 27th, 2008, 08:14 AM
JBfoot's Avatar
JBfoot
Joe Barefoot
'94 D90, '07 D110, '08 LR2, '09 D90
The right and left turn signals are on seperate circuits. When you are having problems with both sides, think about where the circuits might come together. The hazard switch comes to mind first. From your description, my bet is that is where the problem is. Take it out and clean and inspect the contacts. The only other thing that I can think of is a trailer wiring harness. All of the turn indicators come in close proximity there. Good luck!
Old April 27th, 2008, 08:31 AM
draaronr's Avatar
draaronr
Here
LR3
I will try that in a few minutes, so if I don't have trailer wiring I can skip that?
Old April 27th, 2008, 08:48 PM
draaronr's Avatar
draaronr
Here
LR3
that fixed it, thanks Joe.
Old April 27th, 2008, 10:19 PM
JBfoot's Avatar
JBfoot
Joe Barefoot
Yea mon!
signal
Turn signals don't work cdb Defender Technical Discussions 4 April 30th, 2009 11:10 PM
Turn signal clicking like mad Dredd Defender Technical Discussions 8 February 24th, 2009 01:41 PM
