Turn Signals - Defender Source
Old January 21st, 2013, 03:40 PM
bjf's Avatar
bjf
barry f
94 ST #395
Turn Signals
When I signal left everything works fine. When I signal right it doesn't flash on the dash and nothing happens.
Any ideas?
Old January 21st, 2013, 04:00 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
Ground? but I know you already thought of that...strange...
Old January 21st, 2013, 04:21 PM
bjf's Avatar
bjf
barry f
94 ST #395
Could it be a relay?
Old January 21st, 2013, 05:29 PM
Three lefts is a right... Problem solved.
Old January 21st, 2013, 06:26 PM
Glenn_Guinto's Avatar
Glenn_Guinto
Glenn Guinto
94LWB; 99D1; 06RR S/C
That's funny!
Glenn
Old January 21st, 2013, 06:28 PM
WeBeCinYa's Avatar
WeBeCinYa
WeBeCinYa
94 ST #84
It would be worth checking the relays, but also check the connections. Mine were doing something similar and I had to mess with the connections. Works fine now. Other than than you could just replace relays...
1994 Defender 90
2006 LR3 SE
1996 Discovery I (sold)
1991 Range Rover Classic (sold)
1995 Range Rover Classic (sold)
2006 LR3 SE (sold)
Old January 21st, 2013, 06:30 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
If mine did this, I would pull the lever and bypass the lever with a jump wire. If that does not work the switch is good. After that I would check the ground on the light.
Old January 21st, 2013, 06:59 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Get a test light and check the hazard switch pin outs, if relay/fuse are already ruled out.
Old January 21st, 2013, 07:01 PM
bjf's Avatar
bjf
barry f
94 ST #395
thanks
Old January 21st, 2013, 07:22 PM
Bill Larson
Bill Larson
My .02 experiance has alway been a grounding issue...thats not to say it couldnt be anything else. I just got lucky.
Old January 22nd, 2013, 08:01 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Water in the flasher????
Have fixed similar issues when rain water makes it's way into the flasher unit and prevents one of the circuits from operating. Pull the flasher and shake it, if you hear a slosh pry the cover off and drain the water. Blow it off with a hair dryer and try it again. About 50% of the time they work. Then look for the leak. This is usually a result of the vent being left open cause they all leak somewhere.
If not a water issue and the lights are grounded properly, then buy a new flasher. Don't recall the part number but generic ones that work just as well can be had at the local auto supply if you can find a counter chump that will take his nose out of the book and match up a part for a paying customer...
Have you tried the Toyota Dealer for a flasher?
Why would I go there?
You said you have a Land Cruiser...
L--A--N--D R--O--V--E--R !!!
Who makes it ?
Never Mind.
RDavisinVA
Old January 22nd, 2013, 08:18 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Does your hazard switch work? If so does it work all of the lights?
Land Rover 110
Old January 22nd, 2013, 10:34 AM
bjf's Avatar
bjf
barry f
94 ST #395
Which one is the flasher unit?
Old January 22nd, 2013, 10:42 AM
Mud pit potential!
Old January 22nd, 2013, 10:47 AM
Flasher relay location:
http://www.defendersource.com/forum/...7&postcount=40
Old January 22nd, 2013, 10:50 AM
bjf's Avatar
bjf
barry f
94 ST #395
Originally Posted by rijosho
Thank you horsey
Old January 22nd, 2013, 10:51 AM
Thank you horsey
It's nice to see that you two can bicker like an old married couple (yesterday), but then have a sincere heartfelt exchange .
Old January 22nd, 2013, 10:55 AM
I'm always the one who forgives - all he does is use me.
Old January 22nd, 2013, 02:06 PM
bjf's Avatar
bjf
barry f
94 ST #395
Flasher switch doesn't work. Does this mean the relay? Can I just get one at pep boys or is this a rover part.
Old January 22nd, 2013, 02:48 PM
bjf's Avatar
bjf
barry f
94 ST #395
Where do I get the flasher unit?
signal
Mantec Winch Bumper, what do you do about turn signals? Nine-Zero Defender Technical Discussions 1 September 9th, 2012 10:32 PM
No brake lights, turn signals, temp or fuel gauge. John T Defender Technical Discussions 1 August 3rd, 2010 12:54 PM
turn signals and flashers not working draaronr Defender Technical Discussions 4 April 27th, 2008 10:19 PM
Relocating Turn Signals Doug_Paoletti Defender Technical Discussions 13 July 26th, 2005 11:49 AM
