Turn Signals - Page 3 - Defender Source
Old January 28th, 2013, 12:56 AM
bjf's Avatar
bjf
barry f
94 ST #395
Fun times tomorrow
Old January 28th, 2013, 05:34 PM
bjf's Avatar
bjf
barry f
94 ST #395
So the stalk I am going to replace. I couldn't figure it out but it has seen better days. By the time I was done it only worked right if I hold it up slightly. As for the hazards, the fuse is good but they don't work. Would they not turn on if a light bulb was out? I hope I'm not that dumb.
Old January 28th, 2013, 06:06 PM
navydevildoc's Avatar
navydevildoc
Neill Thornton
It's the same fuse for the hazards as your regular turn signals. The fuse is fine.
If your hazards aren't working you will also need a new hazard switch.
Next time you have electrical gremlins we will just have to meet up somewhere and we will work it out.
Old January 28th, 2013, 06:18 PM
bjf's Avatar
bjf
barry f
94 ST #395
I take it there is more to the switch than it just clicking on? I opened it and it looked fine but I will order a new one.
Old January 28th, 2013, 06:37 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Yes there is more to the Hazard switch then the on off. The Hazard switches do go bad. Unfortunately they are expensive. If you can borrow a good one to check it out, before you buy, that would be nice. Then again you can test it to see if it is bad,
http://forums.lr4x4.com/index.php?showtopic=25376
Land Rover 110
Old January 28th, 2013, 06:43 PM
I'd take the hazard apart, clean the contacts, dielectric grease everything, and reassemble. Worth a shot before dropping $75 on a new switch.
Old January 28th, 2013, 06:48 PM
bjf's Avatar
bjf
barry f
94 ST #395
I will say when I press it, it does stop the turn signals from working at all.
Old February 5th, 2013, 06:41 PM
bjf's Avatar
bjf
barry f
94 ST #395
New Hazard switch works perfectly. Can't install the new turn signal stalk because my ghetto steering wheel puller doesn't work. Need a real one.
Old February 6th, 2013, 01:32 PM
bjf's Avatar
bjf
barry f
94 ST #395
New signal installed. Lined up the blue thing correctly yet I have to overturn to cancel. Wtf!!
Old February 6th, 2013, 01:38 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
mine has always been like that...in both 90's. Less so in the SW.
Old February 6th, 2013, 01:39 PM
bjf's Avatar
bjf
barry f
94 ST #395
I don't get it.
Old February 6th, 2013, 01:41 PM
navydevildoc
Neill Thornton
Mine cancels if I turn to the right, but not to the left I think. Might be the other way around.
What did you expect from a Lucas designed part with moving bits?
Old February 6th, 2013, 01:42 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
What condition are the lugs on your "blue thing"?
If they are worn or broken or not engaging the switch the cancel won't work 100%.
Old February 6th, 2013, 02:19 PM
michael67's Avatar
michael67
Michael White
110 Tdi
Brand new, mine used to almost never cancelled on right turns until I soaked the whole area in one of those electrical-safe spray lubricants. Now it cancels, although every once in a while it'll cancel too early, i.e. as I'm starting the turn rather than ending it.
Also make sure the blue things are correctly oriented by testing it with the steering wheel off.
Old March 4th, 2013, 05:22 PM
kiefffff's Avatar
kiefffff
Keith Rider
1994 Portofino ST: #217
Having same issue. No signals and no hazard lights. Have to replace the hazard switch to make it all work. Problem is no one sells the hazard switch anymore.
signal
Mantec Winch Bumper, what do you do about turn signals? Nine-Zero Defender Technical Discussions 1 September 9th, 2012 10:32 PM
No brake lights, turn signals, temp or fuel gauge. John T Defender Technical Discussions 1 August 3rd, 2010 12:54 PM
turn signals and flashers not working draaronr Defender Technical Discussions 4 April 27th, 2008 10:19 PM
Relocating Turn Signals Doug_Paoletti Defender Technical Discussions 13 July 26th, 2005 11:49 AM
