Turn Signals - Page 2 - Defender Source
Old January 22nd, 2013, 03:08 PM
navydevildoc's Avatar
navydevildoc
Neill Thornton
If one side works and the other doesn't, it can't be the flasher unit if I remember right. Doesn't the same flasher provide supply voltage to the switch which decides which side of the truck to flash the lights on?
Old January 22nd, 2013, 05:53 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
One side can fail
The flasher relay (often called flasher unit) can fail on one side, but not the other.
Again this commonly happens when they get water inside.
RDavisinVA
Old January 22nd, 2013, 06:09 PM
It looks like a relay.
1) You can look in the parts manual and get the part number...
2) you can pull it, walk it into VatoZone, past the chrome hubcaps to the back counter and show it to the clerk...
3) You can head or to Marks house and swap it with his while he is at work...
-Jeff
Or search relays for defenders on the AB site, RN site, etc. then match it. Basically, don't be so lazy!
Old January 22nd, 2013, 09:34 PM
bjf's Avatar
bjf
barry f
94 ST #395
Pulled it. Pep boys didn't have so I just ordered it.
Old January 22nd, 2013, 09:46 PM
navydevildoc
Neill Thornton
I just looked at the wiring diagram, I am not sure how this can be as the relay feeds the steering column switch from the same relay output regardless of the side.
Barry, hope replacing the flasher works for you... but I am gonna bet 2 bucks that it's something else.
Old January 22nd, 2013, 10:24 PM
bjf's Avatar
bjf
barry f
94 ST #395
Well the hazard switch doesn't work either so I hope this does it.
Old January 23rd, 2013, 09:13 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
I had my Hazard switch go bad but none of the turn lights worked at all. I haven't heard of only one side but if the whole thing is inop then? Here is a good thread on checking it.
http://forums.lr4x4.com/index.php?showtopic=25376
Land Rover 110
Old January 27th, 2013, 08:01 PM
bjf's Avatar
bjf
barry f
94 ST #395
Relay did not fix the issue.
Turn signal works fine to the left. To the right if I lift the stalk just a little bit it works but if I push it all the way nothing. The hazard switch engages but no hazards. All the fuses are ok.
Thoughts?
Old January 27th, 2013, 08:05 PM
genie90's Avatar
genie90
Jay Geaney
1994 D-90 ST #282
Thoughts?
Did you take the stalk off and clean the contacts? If it's original it may just need a good cleaning...
Good luck
Jay
Old January 27th, 2013, 08:07 PM
bjf's Avatar
bjf
barry f
94 ST #395
I didn't pull it apart yet in the hopes it was something else. Would this affect the hazard switch?
Old January 27th, 2013, 08:22 PM
Did you double check the hazard fuse?
Also, mine acted up early on...I had to pull the hazard switch apart and clean/dielectric grease it and all was good after that.
------ Follow up post added January 27th, 2013 08:24 PM ------
I should also mention that my hazard fuse had issues recently too. One of the "prongs" on the back of the fuse panel (that the fuse goes in) had pushed out just a little bit and was causing intermittent issues.
Old January 27th, 2013, 08:27 PM
bjf's Avatar
bjf
barry f
94 ST #395
Would the hazard fuse affect the turn signal one way? I mean the stalk works if I lift it slightly but the hazard not at all. I would think if it was the fuze I wouldn't get the stalk to work at all.
Old January 27th, 2013, 08:32 PM
Hazards and turn signals are on separate fuses I believe, so may be worth checking. I would think - though not completely sure - that the signal issue and hazard issue are separate. My turn signals worked fine even when my hazard was intermittent on this recent one (related to the fuse). However when my hazard was "stuck" in it killed my signals completely.
I'm just saying its worth checking. When I'd push my hazard fuse in it would push the prong out the back, causing this recent issue for me.
JohnsD90's Avatar
JohnsD90
74 SIII 88", 88 110, 91 110
Clean the contacts first, i had a similar issue on a different vehicle. Solved the problem.
Old January 27th, 2013, 09:03 PM
navydevildoc
Neill Thornton
Thoughts?
Not to say I told you so....
Give me a minute to look at the wiring diagram, I bet we can come up with a 4 step check to figure out what's wrong.
Old January 27th, 2013, 09:45 PM
navydevildoc
Neill Thornton
OK, looking at everything in the diagrams. My wiring diagram is for a '97, but it should pretty much be the same.
The fuse in question is #17, but it's good if your left lights work. After the fuse is the hazard switch, but same thing if your left side is working it's OK (at least as far as getting voltage to the flasher goes). Next is the flasher, which you just replaced.
Then, it goes to the stalk switch. This is where I am putting my 20 dollar bet. Open up the steering cowl, and disconnect the stalk switch. Put a piece of wire between connector 3 (a light green wire with a brown stripe) and connector 4 (A green wire with a red stripe). Make sure the wire jumper isn't touching anything else and then turn on the ignition. Your left hand flashers should be on.
Next, move the jumper over from the Green/Red Stripe wire over to the Green/White Stripe wire, leaving the other end on the Light Green/Brown Stripe. Again making sure nothing else is touching and turn the ignition on again. Now your right hand flashers will be on.
If this works, then the problem is the stalk switch. Try and open it up and clean it all out if you can. Otherwise they are about $100 on different sites.
If the lights are still not working using the wire jumper, we need to move past the switch. But the fact that you say you can coax it into working sounds like the switch needs to be cleaned.
Old January 27th, 2013, 09:51 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I'm with Jason. The two issues are likely not related. Sounds like turn signal is a contact issue and the hazard likely a fuse issue. The stock fuse box is garbage. Make sure the contacts in the fusebox for the hazard are getting a good connection.
Old January 27th, 2013, 11:32 PM
bjf's Avatar
bjf
barry f
94 ST #395
Will check the switch tomorrow. Would the stalk affect the hazards from going on?
Old January 27th, 2013, 11:52 PM
Shouldn't. I'm telling you I think it's 2 separate issues.
Old January 28th, 2013, 12:38 AM
navydevildoc
Neill Thornton
Right. The hazard switch, while connected to the turn signal circuits, doesn't have a way to keep one side from working. If nothing was working, it could be a suspect.
It's gonna be two different issues.
signal
Mantec Winch Bumper, what do you do about turn signals? Nine-Zero Defender Technical Discussions 1 September 9th, 2012 10:32 PM
No brake lights, turn signals, temp or fuel gauge. John T Defender Technical Discussions 1 August 3rd, 2010 12:54 PM
turn signals and flashers not working draaronr Defender Technical Discussions 4 April 27th, 2008 10:19 PM
Relocating Turn Signals Doug_Paoletti Defender Technical Discussions 13 July 26th, 2005 11:49 AM
