Turn signal wonky - Defender Source
Old August 31st, 2016, 06:28 PM
kiefffff's Avatar
kiefffff
Keith Rider
1994 Portofino ST: #217
Turn signal wonky
Failed inspection today. No rear left turn signal. Thought was simple as rear bulb out but new one does not light either. Front left bulb lights fine. Left turn signal indicator flashes super fast. Right turn indicator flashes normal with both bulbs on. Hazard switch works fine. Only left rear bulb doesn't light. Any ideas?
94 Defender
11 Toyota FJ
Old August 31st, 2016, 06:33 PM
Check the contact at the base of the bulb. Needle nose pliers should help pull it out a bit.
Old August 31st, 2016, 06:35 PM
Check the connector for corrosion and replace the bulb socket since that is probably corroded. You can also bust out the volt meter and see if you have power and ground at the connector.
Old August 31st, 2016, 06:41 PM
kiefffff's Avatar
kiefffff
Keith Rider
Thanks guys. Would no contact with the bulb cause the turn signal indicator to flash faster than normal? Acts like there is a short in the wire somewhere.
94 Defender
11 Toyota FJ
Old August 31st, 2016, 06:51 PM
AFAIK, fast flashing only occurs when a signal bulb is blown, or otherwise disconnected.
Old August 31st, 2016, 07:06 PM
kiefffff's Avatar
kiefffff
Keith Rider
Okay. Thanks. Sounds like it should be an easy fix.
94 Defender
11 Toyota FJ
Old September 3rd, 2016, 08:50 PM
kiefffff's Avatar
kiefffff
Keith Rider
Guys. I am baffled. Bulb socket has no corrosion. Very clean. All connectors look good. Checked with volt meter and has power. Yet bulb still won't light. Swapped in new bulb and still no light. What am I missing?
94 Defender
11 Toyota FJ
Old September 3rd, 2016, 08:58 PM
Contractor's Avatar
Contractor
Will
1969 IIA
Are you sure the bulb is making contact with the socket contacts?
Naplm00
Matthew
Use volt meter or circuit tester on the actual wire on the back of the plinth. Put on signal and see if the voltmeter shows action or the circut tester lights up/flashes
If it does not, you aren't getting voltage to the flasher circut or the ground is bad.
You will have to trace the line
Old September 3rd, 2016, 08:59 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
Stab a simple electrical tester into the wire near the socket in question. If it lights up while the signal is on when you might just have a bad socket
Old September 3rd, 2016, 10:52 PM
kiefffff's Avatar
kiefffff
Keith Rider
The volt meter flashes with the turn signal while touching the plinth. Pulled the socket out and made sure connection was solid.
94 Defender
11 Toyota FJ
Old September 4th, 2016, 12:51 PM
kiefffff's Avatar
kiefffff
Keith Rider
I am at the end of my rope. Need someone in CVille area to help. Anyone close by that can lend a hand?
94 Defender
11 Toyota FJ
Old September 4th, 2016, 01:30 PM
lordhelemt's Avatar
lordhelemt
Paul
1995 D90 #2620 & NAS 110
Is CVille Centerville? If so and you can get to Arlington I can lend you a hand. I'd travel but knocking out some projects in the garage
RIP 1994 D90 #999 (engine fire 2002). We'll miss you.
Old September 4th, 2016, 03:15 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Charlottesville
Old September 4th, 2016, 09:27 PM
atpick's Avatar
atpick
Andy
1990 110
Those sockets are historically unreliable. I had this same problem many times. Was mostly a grounding/water infiltration. I ditched the bulbs and switched to LEDs. Installed them in my driveway myself and haven't had any issues since.
signal
Fuel Gauge searching/wonky Davis Defender Technical Discussions 16 May 17th, 2015 12:52 AM
Turn signal in the bumper! Bowtracer Defender Technical Discussions 20 June 7th, 2005 09:18 AM
Turn Signal probs mspell Defender Technical Discussions 7 November 5th, 2004 04:19 PM
Need Turn Signal Switch 48vphantom Wanted 1 September 24th, 2004 01:18 PM
Turn signal--problem solved Davis Defender Technical Discussions 0 July 18th, 2004 07:13 PM
