Turn Signal stalk disassembly - Defender Source
Old May 3rd, 2011, 12:11 PM
Has anyone done this and successfully put it back together? I have the annoying issue of the signal cancelling at the slightest hint of a turn, and wondering about taking it apart to look at it. All the electrical functions are perfectly fine, so would be silly to replace if it could be mechanically repaired. not exactly sure what causes the cancellation internally. Externally, the blue cancellation ring is correctly adjusted for the steering wheel.
Does anybody have an internal picture of a disassembled turn signal assembly so I can see what I would be getting into, and theorize what might be wrong?
Ironically, if I pull the rubber boot of the signal stalk out of it's setting in the steering wheel surround, the cancellation works correctly, so it seems to be cancelling to early based on slight resistance from the rubber boot when seated.
Old May 3rd, 2011, 12:47 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
The springs are worn in the stalk. I've never tried tightening them or changing them but that is why less resistance doesn't cancel it as fast.
Old May 3rd, 2011, 01:12 PM
Actually my problem is quite the opposite. My signal is cancelling too soon, before I have even completed the turn. Only a slight hint of wheel movement will cancel the signal.
Old May 3rd, 2011, 01:46 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
It must be "time" for that repair to be needed on NAS trucks. We have had a rash of that issue recently and haven't seen it much before. We stretched the springs on one to see how long it would last, and it didn't. So we have been replacing the switches.
They are "interesting" to take apart, not hard, but certainly things spring out and if you don't know where they go it can be hard. There are little bars that make the contacts, springs and plastic pads that all fall out when you take it apart.
Email:
Old May 3rd, 2011, 02:09 PM
Thanks for insight. I just spent 20 minutes in the parking lot pulling the wheel off and playing with it further. Turns out it was a problem, now resolved that required further tinkering and refinement with the wheel placement on the column, the blue collar, and the straightness of the front tires. All is well now. Very minor changes seem to have huge impact on the interaction of the wheel and indicator.
Old May 3rd, 2011, 02:31 PM
ECR's Avatar
ECR
If the blue collar/wheel is the issue then you will get "fast cancel" on one turn and long or no cancel on the other turn.
The fingers on the back of the wheel should be straight up and down and the blue collar has a pointer arrow on it that should point directly at the turn signal switch (to the left).
That is the factory set up.
Email:
Old October 4th, 2013, 04:44 PM
reviving this old thread as I finally solved my problem 2 years later. I just installed a brand new turn signal, and after installation, had the exact same issue. Fast cancellation turning right, normal for left. without the stalk rubber boot mounted in the surround, it would operate exactly as it should. Once the boot was set in the surround, same problem. Turns out that without any lubrication, the booth neck on the new switch (and the old switch) didn't have any give to slide as the stalk was turned, pulling back on the stalk causing cancellation early. I pulled out a little vaseline, lubricated the metal stalk and the boot neck interior, reinstalled, and problem solved.
Mark Kellgren
KM4BOR
Old October 4th, 2013, 05:24 PM
taoseno's Avatar
taoseno
Todd Kendrick
1995 D90 #2206 Original Owner
I have the same problem after reinstalling my boot; right cancels too fast left is fine. I will lube up tomorrow and see it that fixes the issue...........
Todd
'95 D90 #2206
'66 109" P/U
Old October 4th, 2013, 09:26 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
I have a new Lucas waiting to be installed, I too will lube up. . Thanks.
Old February 21st, 2014, 07:59 PM
jafir's Avatar
jafir
Jafir Elkurd
If the blue collar/wheel is the issue then you will get "fast cancel" on one turn and long or no cancel on the other turn. The fingers on the back of the wheel should be straight up and down and the blue collar has a pointer arrow on it that should point directly at the turn signal switch (to the left). That is the factory set up.
So if I don't get cancel in one direction and the other direction works fine, and I've verified (corrected) this bit, does that mean the switch is bad?
Old February 21st, 2014, 08:30 PM
GaryBaxter's Avatar
GaryBaxter
Gary Baxter
Try removing the rubber boot and see what happens. I ended up rotating the boot 90 degrees and it solved the problem. Not my weirdest D90 issue but close.
Old February 21st, 2014, 08:57 PM
funny this should pop up today as I was thinking about this issue earlier. Forget my garbage theory, the issue still stands for me. I'm not sure what's going on. lube was a very temp fix that didn't last. Rotating the boot didn't fix it either. Right now I have to keep the boot completely off and pushed out to the end to prevent premature cancellation. Very annoying. It's almost like the whole column shroud is rotated to far in one direction and placing more strain on the boot in one direction than designed.
Mark Kellgren
KM4BOR
Old February 21st, 2014, 09:24 PM
I hit the switch with a bunch of compressed air. A bunch of crap, dust, dirt, and Lucas gremlins flew out and it fixed the problem. Those gremlins come back but so far they haven't found the steering stalk again.
Old February 21st, 2014, 10:42 PM
aaronlam's Avatar
aaronlam
aaron lam
1997 Alpine White D90 SW #2212
I have this issue too. Brand new turn signal assembly so no crap in the boot. Was looking forward to the vaseline fix... oh well.
And yes... same... if I remove the boot... it works fine. I too feel it's catching on something.
assembly, signal
Turn Signal Failure arbik Defender Technical Discussions 53 October 11th, 2010 10:51 PM
94 turn signal stalk CDeWan Wanted 3 January 6th, 2009 10:23 PM
Anyone have the turn signal Wagner/Bosch part number? arbik Defender Technical Discussions 5 February 2nd, 2008 10:33 AM
Need Turn Signal Switch 48vphantom Wanted 1 September 24th, 2004 02:18 PM
