Turn signal relays - Defender Source
Old March 5th, 2008, 10:15 AM
JBfoot's Avatar
JBfoot
Joe Barefoot
'94 D90, '07 D110, '08 LR2, '09 D90
Turn signal relays
I'm replacing my parking/brake/back-up/turn signal bulbs with LED "bulbs". I know that when I replace the turn signal bulbs with LED's, the blinker will flash quickly. There are replacement relays that will put a little resistance in the circuit and cure this. My question is...where are the blinker relays located, and are there one or two relays for the turn signals?
Joe B
Old March 5th, 2008, 10:21 AM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Hey Joe,
One Relay, located near the fuse panel, just above the transmission tunnel, below the dash. For photos and more information, try this thread for more information or This Link to ECR's write-up.
~Scott T.
'95 D-90 ST - AA Yellow
Old March 5th, 2008, 10:24 AM
JBfoot's Avatar
JBfoot
Joe Barefoot
Wow....awesome, that took all of 2 minutes to get the answer. Thanks Scott!
Old March 5th, 2008, 10:34 AM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Joe B
Should be a red relay that's mounted to the backside of the fuse panel on the drivers side.
Jimmy Buffett
Old March 5th, 2008, 10:40 AM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Search is your friend
~Scott T.
relay, signal
Turn Signal Failure arbik Defender Technical Discussions 53 October 11th, 2010 10:51 PM
Anyone have the turn signal Wagner/Bosch part number? arbik Defender Technical Discussions 5 February 2nd, 2008 10:33 AM
Rear turn signal light tron Defender Technical Discussions 3 December 5th, 2005 11:02 AM
Turn Signal probs mspell Defender Technical Discussions 7 November 5th, 2004 05:19 PM
