Turn Signal probs - Defender Source
Old November 4th, 2004, 02:09 PM
mspell
Michael Spellman
Turn Signal probs
My pass side rear blinker is out & the "click" is doing double time. I removed the bulb & replaced it with one that I know works, & it still doesn't work. The hazard flasher doesn't light it up either, so it can't be the turn signal switch. Anyone have any advice on how to get it going? Problem areas, look for continuity in the wires, etc?
TIA
Michael
Old November 4th, 2004, 02:27 PM
Inspect the plugs first. they corrode enthusiastically.
Old November 4th, 2004, 03:32 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
That's how the truck let's you know a bulb is out (the double time clicking). Check the plugs and try and trace the wires as far as possible. The plugs corrode quickly. You may try cleaning off the contacts and see if it works.
Old November 4th, 2004, 03:39 PM
When my wiring drives me nuts because the turn signals don't work I just use the old left arm out the window straight for left turns and left arm out the window at bent at a right angle at the elbow for right turns. But I bet it is like Jim said the holders get a bit dirty and fail to conduct electricity.
Old November 4th, 2004, 03:52 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
funny you mention that Mike. I saw a guy in western MA last weekend doing that while driving a Model T ford..
Old November 5th, 2004, 04:34 PM
Trigger's Avatar
Trigger
Tony Fannin
'94 D-90 #491
My indcators are even more maddening. Since the accident I've been getting intermitent problems. When using the left turn signal the trailer light blinks and both rear indicators blink. I've been trying to figure it out but have given up. I just do the old arm out the window bit.
A Land Rover would never turn up to collect an Oscar, it'd be far too busy doing something important somewhere for someone - Top Gear
Old November 5th, 2004, 05:03 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Tony, did you check the wires and harness where it exits the fram on your rear end? I would bet some of the wires chafed.
Old November 5th, 2004, 05:19 PM
Trigger's Avatar
Trigger
Tony Fannin
'94 D-90 #491
I've looked, can't find a problem. I just need to stop being lazy and start tracing/testing wires. It's just easier to use the arm.
signal
Turn Signal Failure arbik Defender Technical Discussions 53 October 11th, 2010 10:51 PM
Anyone have the turn signal Wagner/Bosch part number? arbik Defender Technical Discussions 5 February 2nd, 2008 10:33 AM
Rear turn signal light tron Defender Technical Discussions 3 December 5th, 2005 11:02 AM
Need Turn Signal Switch 48vphantom Wanted 1 September 24th, 2004 02:18 PM
