Turn signal--problem solved - Defender Source
Old July 18th, 2004, 08:13 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I remember a month or so ago that someone had the same issue as I did in that your turn signal did not turn off when completing a left hand turn. I knew I would dig into it the next time I had my steering wheel off (I was not going to remove it "just" for this problem) and I finally took it off to straigten it after installing a front locker. On the steering column behind the wheel is a plastic sleeve (mine was blue) that has two notches in it. On the back of the steering wheel, there are two protruding tongs made of metal that have to engage in this piece of plastic. When I had not noticed previously, I reinstalled the wheel without centering this and hence I had the problem. When I reattached the steering wheel this time and appropriately aligned these tabs, all was good and forgiven. Max loves me again.
signal
Turn Signal Failure arbik Defender Technical Discussions 53 October 11th, 2010 10:51 PM
Anyone have the turn signal Wagner/Bosch part number? arbik Defender Technical Discussions 5 February 2nd, 2008 10:33 AM
Rear turn signal light tron Defender Technical Discussions 3 December 5th, 2005 11:02 AM
Turn Signal probs mspell Defender Technical Discussions 7 November 5th, 2004 05:19 PM
