Turn Signal Issue (ARB bumper?) - Defender Source
Old November 19th, 2015, 05:21 PM
jperakis
James Perakis
94 ST
over the last month when i would hit my turn signal i go a buzz from the relay (pektron).
First the left turn signal stopped working all together, then the right went out not long after.
When I hit the hazard the front right and both rear bulbs flash properly.
This leads me to believe it's not the flasher relay that is out (duh).
The driver's side bulb on my ARB does not flash.
I'm assuming this is the source of my issue.
I pulled the housing and everything looks good... solid contact... bulb isn't blown.
Moreover my fuse looks good.
What's going on here?
Any recommendations?
remember two things...
Old November 19th, 2015, 06:07 PM
quick968's Avatar
quick968
Mikey
97 Defender 90
Quick diagnosis, swap the working front bulb to side not working. If it works there, you know the other bulb is bad. If it doesn't work, you know the bulb fixture is bad and can start trouble shooting that. Could be corrosion inside the fixture, or at wiring connectors, or the wiring itself. But the bulb swap is a quick way to start.
Cheers
Mikey
arb bumper, bumper, signal
Electrical issue? Turn Signal / Brake pedal Flagg Defender Technical Discussions 5 November 9th, 2012 02:08 PM
ARB Bumper Turn Signal Replacement fleabus Defender Technical Discussions 4 February 29th, 2012 05:09 PM
Amber turn signal for stock front bumper WhiteD90 Wanted 3 October 2nd, 2009 11:37 AM
Wanted: 1994 front bumper with turn signal lights dfscott Wanted 0 October 6th, 2008 07:49 AM
Turn signal in the bumper! Bowtracer Defender Technical Discussions 20 June 7th, 2005 10:18 AM
