Turn signal in the bumper! - Defender Source
Old June 2nd, 2004, 04:03 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Is there a way to change the turn signal on a d110 from the bumper to the ones by the head lights?!?!?
Peter
Old June 2nd, 2004, 04:23 PM
Art Vigil's Avatar
Art Vigil
Arthur Vigil
Yes, there is a way.
I don't know how to do it myself, but I do know that East Coast Rover used to sell a kit that made it possible.
Best of luck,
Arthur M Vigil
Colorado Native
Former owner of:
'95 RRC - 3.9V8 Rimmer Supercharged!
'72 Series III 88" NADA Turner 2.25 petrol (Lovely Rita)
'95 RRC Brooklands/TWR Edition 3.9V8
'97 D90SW NAS #2426 - 3.9V8 Rimmer Supercharged!
'95 D90ST NAS#2620 - Original owner
Old June 2nd, 2004, 04:26 PM
PT94D90's Avatar
PT94D90
Phil
Currently Defenderless
I have the step-by-step instructions from ECR. Send me your e-mail address if you want them.
Old June 2nd, 2004, 04:48 PM
Can't you just cut the wires from the bumper turn signal and run them to one of the marker bulbs, change the marker bulb to a differnt wattage (it's listed here someplace Tyler just did it) and presto your done?
Old June 2nd, 2004, 04:50 PM
scoloco's Avatar
scoloco
'94 D90 ST
I did the following on my '94.
1. snip the wire to the lower bezel leaving a decent tail from the bezel.
2. snip the wire to the blinker.
3. hook up the blinker wire from harness to the bezel tail
4. go to <local auto parts store> and get a 105 bulb.
5. insert said bulb, and bobs your uncle, fannys your aunt...
HTH
Old June 2nd, 2004, 04:53 PM
this is the one
http://www.defendersource.com/forum/...ead.php?t=1675
Old June 2nd, 2004, 04:57 PM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
Thats what I did on our '94 but still have to replace the bulb with the proper one. BTW I went to the top bulb. For some reason the bottom ones didnt work.
Chris von C
[/size]
Old June 2nd, 2004, 05:14 PM
loykd's Avatar
loykd
Ken Loy
1994 Portofino Red ST
When I rewired mine, they were caked with mud. (I'm sure it was because of the previous owner. :=) I didn't snip any wires, instead, I pulled the bullet connectors from the lucar connector, cleaned the connections, and reassembled. Figured that's a better way until the next time I need to change something out. A neighbor has a sandblaster and he cleaned all the connections on the bulb assembly too!
If you want to directly wire them, I'd suggest soldering and shrinkwrapping to protect against that nasty mud. (always thinking about the next owner, which will be a LONG time from now, I hope)
Old June 2nd, 2004, 05:22 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
I am not sure what you are talking about? I do not want to snip wires. I am trying to figure a least invasive methed. The bulb # is great!
Old June 2nd, 2004, 08:39 PM
loykd's Avatar
loykd
Ken Loy
I got these from Phil who got them from ECR:
> > Remove the signal lights and the headlight trim and
> > headlight.
> > Follow the wiring from the turn signal that is in
> > the bumper. It will go through a grommet in the
> > lower fender. Follow it until you find where it
> > plugs into 2 black barrel like fittings (called
> > Lucar connectors). Unplug the bumper lamp wiring.
> > Then follow the wires from the back of the lower
> > parking light. Remove these wires from their Lucar
> > connectors (they just pull out, unless corroded)
> > then plug these wires into the Lucar connectors that
> > the old bumper turn signal used to turn into. This
> > converts the lower parking light into a turn signal.
> > Now replace the bulb with an 1156 bulb from your
> > local parts store and you are done. Well, you have
> > to do the other side.
> > If you want to get really trick you can order a
> > stop/tail light from Rovers North #RTC5523 and wire
> > it up so that you will still have both upper and
> > lower parking lights (same theory as above) but you
> > will also connect the red parking light wire as
> > well. Then toss the red lens they sent with it and
> > install your old amber lens. This will keep your
> > factory look, but will give you a turn signal in the
> > lower lamp.
> > Sometimes this simple swap can be a bitch becuase
> > Rover didn't leave the wires very long, so it can be
> > aggrevating to get everything plugged in.
> > Have fun!!
> > ECR
Email me if anything doesn't make sense. If you take these to the truck with you, it'll be a little more clear. I'd also be prepared with some stuff to clean the corrosion off of all the connectors and perhaps some dialectric grease when you put it all together again.
Old June 3rd, 2004, 10:58 AM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
Thanks, I could not find one of the lucor connectors! THANKS< TO ALL!!!!
Peter
Old June 10th, 2004, 03:09 PM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
I saw this thread a while back, and I've been meaning to ask: What's the reason for changing the front turn signals from the bumper to the marker lights? Is it only for aesthetics or is there some functional reason? Thanks.
Old June 10th, 2004, 03:29 PM
Glenn_Guinto's Avatar
Glenn_Guinto
Glenn Guinto
94LWB; 99D1; 06RR S/C
Ryan, a lot of people that replace their stock bumpers to aftermarket ones (i.e. Safarigard) that don't have a place for a turn signal are usually the ones doing this method. Not that you can't do it with stock of course, but then that would just be for aesthetic reasons.
Glenn
Old June 10th, 2004, 03:57 PM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
Ok, now I understand. I've got an ARB so the turn signals are in the bumper. But I'd like to get a Rockware so I'll need to remember this thread when I do that. Thanks Glenn.
Old June 6th, 2005, 11:58 PM
jabber
m j
110
So I need to bring this thread up again... I followed the instructions for the lower light (plugging it into the wire feed that originally went to the bumper lights). The turn signal works fine, but that's it! When I turn the lights on the newly created directional isn't lit. I thought the lower light should light up then blink with the directional on.
I'm using the 105 bulb... Picked it up from Napa. Any ideas???
Old June 7th, 2005, 08:08 AM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Nope. That lower light should stay off untill you use the turn signal.
Jimmy Buffett
Nope, the light only works like a blinker in this configuration, it will not come on when the other lights are on.
Old June 7th, 2005, 09:29 AM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
I belive there is a kit to turn that light into a duel action signal. ?! Rovers north? It would be a new socket & you would be good to go
Old June 7th, 2005, 09:38 AM
Well it's not to hard to do yourself using a dual filiment bulb and a new bulb socket, you should be able to get both at the auto parts store.
Old June 7th, 2005, 10:10 AM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
George would have what you need! I am sure for pretty reasonable! Hes a good dude!
bumper, signal
Turn Signal Failure arbik Defender Technical Discussions 53 October 11th, 2010 10:51 PM
Anyone have the turn signal Wagner/Bosch part number? arbik Defender Technical Discussions 5 February 2nd, 2008 10:33 AM
Rear turn signal light tron Defender Technical Discussions 3 December 5th, 2005 11:02 AM
Need Turn Signal Switch 48vphantom Wanted 1 September 24th, 2004 02:18 PM
