So I've recently had an issue whereby when I flip the left turn signal, the hazards come on, when i flip the right signal, the hazards come on, and when i flip the hazard button, nothing happens. Concurrently, my horn no longer works. I've not much experience with electrical stuff, but I figured it may be a ground somewhere in the system. Any ideas?:icon_peace:
check your connections to the front harness, the 'ground' screw on the lights I believe you can access if you pull the lens cover off and ground clip to the frame. I think you could test the lights like this for grounding issues though I personally haven't tried it.
Might be easier to troubleshoot if electronics aren't your fancy.
Given that your horn is on the turn signal stock I think it could be that switch is shot. Doesn't seem as common as the headlight switch but we are talking about an original part I am sure.
Could also be the hazard switch as those are known to go
Related Threads
Defender Source Forum
1M posts
24K members
Since 2003
