Turn Signal fuse blowing - Defender Source
Old June 6th, 2014, 11:33 AM
toad's Avatar
toad
Cutter
I am trying to track down an electrical gremlin in my new to me 86 110. The fuse that the turn signal is on is blowing. I replaced the turn signal switch with a new unit but it is still blowing. When I put a new fuse in it works for a bit, the trailer dash light turns on intermittently when I use the left indicator. When the fuse blows and I engage the hazards the trailer dash light blinks instead of the indicator light.
I've seen in searches that the hazard switches on these goes, I'm thinking this is the next thing to check but I'd like to see what else is on the circuit that could be doing this since the signals seem to work just fine when before the fuse blows.
Old June 6th, 2014, 11:36 AM
I'd guess a short. Ie bare wire touching ground somewhere.
Old July 20th, 2014, 04:44 PM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
I'm having the same type of problem. I replaced all of the driving lights and turn signal assemblies front and back along with a new turn signal/horn stalk, and when I engage the turn signal in either direction, I can hear the relay clicking and then the fuse blows. Neither bulbs will flash though.
Shorting problem as well? I'm thinking reversed leads, which would translate to the same?
Thank you - Samer
1997 P38 Vitesse (Red)
2003 Discovery II
Defenderless, for now!
Old July 21st, 2014, 10:12 AM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
Bump
Thank you - Samer
2003 Discovery II
Old July 22nd, 2014, 10:48 AM
Nashville's Avatar
Nashville
Victor Hess
1997 Defender 90 NAS
I'm sure it was a complete coincidence, but only my trailer light would come on when I used the turn signals. This went away when I replaced all the warning light bulbs in the dash and the indicator blinker worked again. I haven't seen the trailer light since.
1997 D90 ST NAS #1426
British Racing Green
Old July 22nd, 2014, 10:52 AM
KKilo23's Avatar
KKilo23
Kenny
Short. I had the same issue before I replaced my harness. A wire frayed and was touching the metal on the frame. Just need to track it down.
Old July 22nd, 2014, 11:03 AM
samer0214's Avatar
samer0214
Samer Hijazi
1997 P38 Vitesse
I went back and rechecked all 4 turn signal assemblies yesterday and found out that I had reversed the connections on the 2 front ones. The color coding of the wires was reversed during manufacturing. I also made shure that all bulbs were fine by feeding them a 12 volt signal.
The good news is that the fuse in no longer blowing, but I still have a problem:
1) the immergency flashers will not work when I activate the flasher button in the dash, unless the turn signal stalk is also activated in either direction (it doesn't matter if it's left or right)
2) the turn signal itself doesn't work all the time, it's intermittent, and only seems to work properly after I "reset" the circuit by turning the flashers on and off
3) the left rear corner turn signal is not working at all, whether I activate the flashers or the turn signal stalk
BTW, the turn signal stalk is completely new.
Thank you - Samer
2003 Discovery II
Old July 22nd, 2014, 11:18 AM
Sam,
Did you try changing the hazard switch? That or the flasher cure 90% turn signal issues. As for Toads issue(s) it sounds like an intermittent short somewhere in his system.
signal, wing
Fuse Box: Glass fuse --> Spade Fuse gonzanc Defender Technical Discussions 20 October 27th, 2016 11:54 PM
60amp accessory fuse B blowing in main fuse box owen Defender Technical Discussions 5 March 31st, 2013 09:18 AM
Quick ?, do front turn signal wires go directly to the relay behind fuse cover Neil McCauley Defender Technical Discussions 3 January 6th, 2012 08:23 PM
Repeatedly blowing undehood 30A fuse Hans Defender Technical Discussions 1 September 6th, 2005 04:24 PM
Blowing wiper/speedo fuse like crazy....help! P1CR Defender Technical Discussions 4 March 11th, 2004 03:23 PM
