Turn Signal Failure - Page 3 - Defender Source
Old October 7th, 2010, 11:10 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
So the plug where the flasher attaches has a slot (but no metal pin) for the 5 pins on the new flasher. I didn't even need to modify it to plug it in. The problem is, that didn't fix it. I jiggled the hazard switch some more to no avail. This is getting really annoying. I guess the next step is replacing the turn signal switch module behind the wheel?
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old October 7th, 2010, 11:22 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
You probable want to get out a multimeter and start tracing things so see what gets power/ground and what doesn't and at what point.
Old October 8th, 2010, 08:06 AM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
The plastic collar breaking perfectly timed with the signals not working has to be significant.
Its possible the relay was also fried, but I think I now need to replace the signal switch on the column regardless.
At this point I'm thinking of bringing it somewhere... I just want to drive it!
~2008 GTI TSI
Old October 8th, 2010, 09:16 AM
MonLand
Loic Fabro
95 D90 - 96 Disco -06 LR3
I would be surprised if the flasher relay you bought just fits -if- the only thing you guys looked at are the number of pins (and pin orientation). Is there a diagram on the LR part?
Now reading the posts above, it looks like the warning lights are on a different circuit, are those working?
MonLand
1995 D90 NAS
1996 Discovery NAS
Old October 8th, 2010, 09:31 AM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
No indicators at all, turn or warning
~2008 GTI TSI
Old October 8th, 2010, 11:33 AM
draaronr's Avatar
draaronr
Here
LR3
dude its the signal indicator switch, just call RN, tell them which plug you have and they will ship you one, will take you 15 minutes to change.
Old October 8th, 2010, 11:37 AM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
will do.
Thanks Doc.
~2008 GTI TSI
Old October 9th, 2010, 03:16 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
group was right, replaced switch with new one from Atlantic British (along with flasher), flashers/hazards work again.
FYI the steering wheel needs to be pulled to replace the switch.
~2008 GTI TSI
Old October 10th, 2010, 08:33 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
Interesting side effect to the new switch/flaher...
I think there is voltage leaking into the flasher bc its clicking (slightly) while driving when the turn signal/hazards aren't on.
I noticed that any time any other light is on (hitting the brakes and/or running lights) is enough to prevent this.
I'm thinking that the "leak"/crossed wire is in the trailer wiring due to when I do use the turn signals the trailer dash light lights up very slightly at the same rate...
~2008 GTI TSI
Old October 10th, 2010, 09:01 PM
KKilo23's Avatar
KKilo23
Kenny
It is the wrong flasher. I had the same thing happen. Changed flashers and everything was fine.
------ Follow up post added October 10th, 2010 09:03 PM ------
I believe that flasher from AB is a britpart flasher and not genuine. Not that means anything, but I tried it in my truck and I had the same issues. Get a genuine one from RN and you should be fine.
I still have to get that part number for you on the one I got at the local auto parts store...b/c that works fine as well..
Old October 10th, 2010, 09:18 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
Got a part number for the correct one?
~2008 GTI TSI
Old October 10th, 2010, 09:22 PM
KKilo23's Avatar
KKilo23
Kenny
http://www.roversnorth.com/store/p-5...-defender.aspx
I'd verify with RN....I do have a 97.
Old October 11th, 2010, 10:38 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
I sourced the Tridon EP26 4-pin flasher locally, $15. Works perfect now.
~2008 GTI TSI
Old October 11th, 2010, 10:51 PM
KKilo23's Avatar
KKilo23
Kenny
Glad to hear. Btw your switch might not have been bad.
signal
Anyone have the turn signal Wagner/Bosch part number? arbik Defender Technical Discussions 5 February 2nd, 2008 10:33 AM
Rear turn signal light tron Defender Technical Discussions 3 December 5th, 2005 11:02 AM
Turn Signal probs mspell Defender Technical Discussions 7 November 5th, 2004 05:19 PM
Need Turn Signal Switch 48vphantom Wanted 1 September 24th, 2004 02:18 PM
