Turn Signal Failure - Page 2 - Defender Source
Old April 22nd, 2005, 07:56 AM
950rider
Matt Warren
Arbi, do you happen to have a land rover part number for that hazard flasher? And is there a separate flasher for the normal turn signals?
Thanks!
Matt
Old August 30th, 2009, 03:44 PM
phoenix37's Avatar
phoenix37
john
Is it common for the relays to go bad? My signals just stopped working. Fuse still intact.
Old August 30th, 2009, 09:22 PM
phoenix37's Avatar
phoenix37
john
Anybody? Neither my hazards nor my turn signals work. I know they are separate fuses and relays so why would they both fail? Any info before I go buy both relays would help.
Old August 30th, 2009, 10:24 PM
It is probably the hazard switch. jiggle it and push it a couple times and see if it starts working again.
Old August 30th, 2009, 10:42 PM
phoenix37's Avatar
phoenix37
john
Will do. Thanks Ron.
What are the two purple wires that come out of the bundle of wires behind the flasher relay? Mine arent connected to anything.
Old August 31st, 2009, 03:37 AM
Purple is usually interior lighting (among other things) but I am not familiar with those two wires in particular.
Old August 31st, 2009, 07:58 AM
phoenix37's Avatar
phoenix37
john
Youre a genius! That did it.
Old August 31st, 2009, 10:04 AM
No problem.
Old October 1st, 2010, 07:19 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
bumping this thread.
on my drive back from Crazy Ray's today I lost turn signals (hazards dont work either).
Checked all fuses (don't know how to tell if a flasher is bad unless i just swap it out)
Jiggled the hazard switch, no dice.
I took the plastic upper/lower cover off of the steering column (after noticing that it moves a bit more than it should when I used the stalk (wiper and turn). The bottom screw was missing and I saw that the plastic "collar" that holds it around the actual column is broken... Coincidence?
Advice?
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old October 5th, 2010, 03:10 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
no ideas? I'm going to swap out the flasher this week and see if that fixes it.
~2008 GTI TSI
Old October 5th, 2010, 07:56 PM
SeattleRRC's Avatar
SeattleRRC
Woody
1990 RRC SWB, 1994 D90 ST
I had the same problem - my advice is keep jiggling the hazard switch. I pushed it in/out a bunch. eventually I got it to sit in just the right position and everything worked again. Everything has worked perfectly and its been 8 months since the signals/hazards acted up. Didn't have to replace anything.
Old October 5th, 2010, 08:20 PM
KKilo23's Avatar
KKilo23
Kenny
Check your relay... I had the same issue..
Old October 5th, 2010, 08:51 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
will do both, thanks
~2008 GTI TSI
Old October 7th, 2010, 12:05 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
will change relay today.
Any idea if its a rover specific part? will an autoparts chain store carry it?
~2008 GTI TSI
Old October 7th, 2010, 12:09 PM
KKilo23's Avatar
KKilo23
Kenny
NAPA or Autozone/Advanced Auto should have it. I don't have the part number, but I can check later. That is what I put in the truck. $15 compared to genuine $50 one. Its basically a heavy duty flasher realy for imports IIRC.
Old October 7th, 2010, 01:32 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
any advice about the broken plastic collar thing? AB doesnt carry it, neither does RDS or Rovers North
~2008 GTI TSI
Old October 7th, 2010, 02:26 PM
KKilo23's Avatar
KKilo23
Kenny
Try Stephen at Safari Rover... Will Tillery..
Old October 7th, 2010, 06:04 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
Anybody have a part number for the flasher? I'm @ autozone and they don't have any idea where to look...
~2008 GTI TSI
Old October 7th, 2010, 07:41 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
sorry for the addt'l bump
Here's the closest thing that 3 different parts stores had...
The 4 pins that are the same line up, its the 5th one that is the concern. I was thinking about just breaking it off and trying it out.
Thoughts?
~2008 GTI TSI
Old October 7th, 2010, 10:13 PM
Ronanmd1
Jason
1997 D90 HS2.8
Check pm
Jason
signal
Anyone have the turn signal Wagner/Bosch part number? arbik Defender Technical Discussions 5 February 2nd, 2008 10:33 AM
Rear turn signal light tron Defender Technical Discussions 3 December 5th, 2005 11:02 AM
Turn Signal probs mspell Defender Technical Discussions 7 November 5th, 2004 05:19 PM
Need Turn Signal Switch 48vphantom Wanted 1 September 24th, 2004 02:18 PM
