Turn signal clicking like mad - Defender Source
Old February 23rd, 2009, 02:13 PM
Dredd
Harlan Boone
Unhappy Turn signal clicking like mad
My turn signals and flashers work fine, but after I use them I hear a fast double-clicking for up to several minutes. Bulbs are okay.
Anything else to check?
HB
Old February 23rd, 2009, 02:49 PM
khouseal's Avatar
khouseal
Kevin Houseal
1994 NAS D-90
Back in the old days, in my cars, that used to mean the silver flasher box under the dash was going. Sometimes it was a small cylinder shaped, sometimes a box. I don't know what the D90 uses.
Old February 23rd, 2009, 07:38 PM
mjekogian's Avatar
mjekogian
Michael Jekogian
1997/ Defender ST
you have a bulb out somewhere
Old February 23rd, 2009, 09:10 PM
NashvilleRover's Avatar
NashvilleRover
Dendy Jarrett
2009 LR3- Well Built
Flasher unit is behind the speedo panel. (I believe in all 90s)
If you hear the noise from behind there, the person that pointed out your flasher unit going bad was probably point-on.
Just my opinion ... mind you
Dendy
Old February 23rd, 2009, 09:28 PM
hamiamham
mike
97 D-90
have the same problem. one of my bulbs is out. obviously very easy to rule out a bulb..
Old February 24th, 2009, 02:05 AM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Just trying to make sure I have it right.....
When you use them initially, they are fine. But after you turn, the thing keeps clicking rapidly for a few minutes? I would also suggest replacing the flasher unit.
-Hans
My oil line fix
My 100k stopped odometer fix
Old February 24th, 2009, 03:14 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
If you need a flasher, I have a stock one I can spare.
Old February 24th, 2009, 09:33 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
After a really wet drive, the bulb would be fine but the bulb holder contacts break. Over the last year I most have bought 6 of them.
From the description it sounds like Dredd's is something else but I would know I had a shot holder when I heard the rapid blinking when I used my turn signal.
Old February 24th, 2009, 01:41 PM
Dredd
Harlan Boone
-Hans
Correct Hans. The bulbs are all fine.
New flasher is on the way. Thanks for the offer Andrew.
HB
signal
Turn Signal Failure arbik Defender Technical Discussions 53 October 11th, 2010 10:51 PM
Anyone have the turn signal Wagner/Bosch part number? arbik Defender Technical Discussions 5 February 2nd, 2008 10:33 AM
turn signal clicking Caribsurf Defender Technical Discussions 5 October 31st, 2006 04:17 PM
Rear turn signal light tron Defender Technical Discussions 3 December 5th, 2005 11:02 AM
