turn signal bulb - Defender Source
Old December 19th, 2013, 06:13 PM
CaptMidnite
Daniel Choi
94 NAS Defender 90 ST
turn signal bulb
This should have been simple: tried to change out one of the front turn signal bulbs. Lightbulb wouldn't move out of socket, ended up separating glass bulb from metal socket. Used pliers in attempt to get detached metal base out, still wouldn't move. Is there an easy way to remove it I am missing? Some sort of clip that pops it out after you press it? Or is the socket severely corroded? If so, how to remove and fix?
Anyone have pictures of a cleanly disassembled turn signal socket?
Old December 19th, 2013, 06:43 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
Looks like it might be time to get some new ones. No easy way to fix corrosion. If that is in that condition the other may be the same.
Old December 19th, 2013, 06:46 PM
CaptMidnite
Daniel Choi
Thanks, so I assume a clean one should just let the bulb pop out with a little bit of effort? I see a spring on the bottom.
Old December 19th, 2013, 07:13 PM
Capt Milks's Avatar
Capt Milks
Yep, a new one the bulb goes in and out pretty easy. Some of those plastic ones get nasty pretty quick. The newer style doesn't do it like the one you posted.
Scottyoh's Avatar
Scottyoh
Enigma RnR
'87 127"
It is best to replace those yes, but they can be saved most of the time. To do so you will need needle nose pliers. You need to pinch the side with the pliers and push towards the center. Collapsing the sides enable you to pull the remainder of the bulb out. You can do that or pinch the side with the pliers, push down, and turn it counter-clockwise. Either way has worked for me. Just clean the socket afterwards with battery terminal cleaner and use dielectric grease.
I can ship you replacements if you're interested, OEM or LED options available.
Old December 19th, 2013, 08:16 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
You need to push the bulb in when you turn. Grab whats left with pliers, push and then turn.
-Jeff
Man I had to double take who wrote this nonsense because of the avatar! It really freaks me out when folks change their stuff so much!
Old December 20th, 2013, 05:23 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Always liberally apply dielectric grease to bulb bases before installing.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
signal
Turn Signal Failure arbik Defender Technical Discussions 53 October 11th, 2010 10:51 PM
Anyone have the turn signal Wagner/Bosch part number? arbik Defender Technical Discussions 5 February 2nd, 2008 10:33 AM
Rear turn signal light tron Defender Technical Discussions 3 December 5th, 2005 11:02 AM
Turn Signal probs mspell Defender Technical Discussions 7 November 5th, 2004 05:19 PM
