Turn signal & hazards not working - trailer light on - Defender Source
Old November 1st, 2013, 05:27 PM
Howski's Avatar
Howski
Kevin
2002 Land Rover Discovery II
Well my turn signals decides to stop working on me in the middle of a trip. I had used the hazards several times and now the trailer light is on. Any help would be appreciated. Checked the fuse, it seems fine
My other car's a Land Rover
Old November 1st, 2013, 05:53 PM
Bad hazard switch is what I would place my bet on.
Old November 1st, 2013, 05:59 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Check you grounds
Howski's Avatar
Howski
Kevin
Any way to get around it for the rest if my trip like removing the switch?
Old November 1st, 2013, 06:09 PM
Not that I am aware of. You may try squirting electric contact cleaner into the switch. Worth the couple of bucks the can would cost.
Old November 1st, 2013, 09:26 PM
I would start jiggling all of the connectors around your indicator lamps. Sounds like a bad ground to me.
Old November 1st, 2013, 11:39 PM
Green Blood's Avatar
Green Blood
Carl Phillips
1988 90- Swiss LHD 2.5 Petrol
I've had a similar situation on my truck lately (intermittent) and it seems to be related to the switch. If I wiggle it around a bit it will work fine. Feels like it has a lot of free play from worn contacts.
So I'd second the contact cleaner as a potential quick fix until you can further diagnose.
Proud restorer and former owner of '94 NAS D90 #590- back in the hands of its original owners.
And now happy owner of a 1988 Swiss-Market D90 Station Wagon.
Old November 2nd, 2013, 12:43 AM
I agree time for a new turn signal switch
Old November 3rd, 2013, 04:18 PM
Green Blood
Carl Phillips
Okay, now I'm not so sure my issue is the switch. My intermittent lack of flashing is now happening more often than not and there is no flashing with the hazards either, so I'm thinking the flasher unit is bad.
Looks like I will need to do a bit of research on this.
Can anyone tell me where the flasher is located?
Old November 3rd, 2013, 07:44 PM
Sounds like a bad hazard switch. Just give it a gentle pull. And all should start working again.
Old November 3rd, 2013, 08:53 PM
Reese_D90's Avatar
Reese_D90
Reese
97 D90 ST and 93 D110
Mine did the same thing. I had used the hazard, then blinkers stopped working. The hazard button was not fully off. Pushed the hazard button a couple of times and all was good.
NAS 1993 D110 CDN #11/25
1997 D90 ST #1953
2006 Range Rover
1997 D90 SW #701 (sold)
1995 D90 ST (sold)
Old November 3rd, 2013, 08:56 PM
pulling gently works better ...
Old November 4th, 2013, 08:29 AM
Howski's Avatar
Howski
Kevin
Thanks for all the responses. After sitting for two days, I cranked the truck back on and miraculously the turn signals work again. As has been mentioned I think it was the hazard switch getting stuck. I'll have a new switch on order but I'm just glad I had turn signals for the long ride back.
Old November 8th, 2013, 06:02 PM
Green Blood
Carl Phillips
Sorted mine, it was the hazard switch. I found some great instructions. Rom a thread here on how to diagnose. I took the switch apart (which was surprisingly easy to do), cleaned it and put it back together again. Now my signals are working fine but I do think I'm going to order a new switch just in case.
Certainly seems like a wonky way to go about wiring the circuit but as with most British electrics, not surprising.
Old November 9th, 2013, 02:26 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Yeah, Hazard circuits are always a mess. We just had one in the shop, same thing, the signals only worked if you held the hazard switch.
Turn signal problem Freeser Defender Technical Discussions 6 September 10th, 2013 08:57 PM
Turn Signal switch may be shot- scout159 Defender Technical Discussions 2 March 11th, 2010 08:09 PM
Turn signal in the bumper! Bowtracer Defender Technical Discussions 20 June 7th, 2005 10:18 AM
Reverse Light is Slow to Turn On-Why? JRowe Defender Technical Discussions 1 December 12th, 2003 05:03 PM
Trailer Light Connector loykd Defender Technical Discussions 3 November 17th, 2003 04:31 PM
